587,281 active members*
4,988 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > G41 Cutter Comp Error
Results 1 to 5 of 5
    Dec 2010
    24
    Just got v11 and trying to do some tests, but having some problems with cutter comp as output by the post processor. I have a Dynapath Delta 10 controller. Following is a simple file straight from the post processor for that controller. Just a square with a circle in the middle.
    The program seems to run fine until line 185, which is g41 cutter comp left. This controller excepts G40, 41 and 42. But I get an error with g41 in this program.
    I run the same program with the offset to none, g40 and the program ran all the way through.
    So I'm not sure if it's looking for something before line 185? I also noticed that the post is adding several g codes to the first line, which my manual says there can only be one g command per line.
    Can anyone help with this issue?
    N5G70G40G17G90G80
    N15T1M06
    N25S1225M03
    N35G00X0.0Y0.0F5.0
    N45Z1.969
    N55X0.75Y0.0
    N65Z0.125
    N75G01Z-0.5
    N85G03I0.0J0.0
    N95G01X0.375Y0.0
    N105G03I0.0J0.0
    N115G01X0.188Y0.0
    N125G03I0.0J0.0
    N135G00Z1.969
    N145S1225
    N155X-2.006Y2.257
    N165Z0.125
    N175G01Z-0.5
    N185G41X1.992Y2.257D1
    N195G02X2.242Y2.007I1.992J2.007
    N205G01X2.242Y-2.007
    N215G02X1.992Y-2.257I1.992J-2.007
    N225G01X-2.006Y-2.257
    N235G02X-2.256Y-2.007I-2.006J-2.007
    N245G01X-2.256Y2.007
    N255G02X-2.006Y2.257I-2.006J2.007
    N265G40G00Z1.969
    N275M30
    Oct 2010
    317
    N5 is a safe start line, it cancels most and you need a linear move after activating cutter comp before it will take effect so either add another line before the G02 or move the G41 command to a new line before N185 and then change 185 to a G01. Your control should take multiple G codes on a line, most I am familiar with wont take more than one M code.
    Try moving G41 to N180 and change G41 on 185 to G01, if that doesnt work you will need to put G41 on N155.
    Dec 2010
    24
    I agree, N5 looks suspect. This was the code generated straight for the post processor. Also noticed on that line there is a g40, no comp and is also modal. According to the manual I have for this controller, it cancels out any proceeding g41 or 42. Does this sound correct?
    Just looking for a way to output clean code from Dolphin without modification, or am I asking to much? Will this be a case that I'll have to modify every code that comes out of Dolphin?:devious:
    Oct 2010
    317
    Yes N5 is a common line, it is used to cancel anything that may not have been canceled before...cutter comp G40, drill cycles G80, etc...
    You can edit a post processor to make it output the correct code. There may be one available already.
    Are you sure your control wont accept multiple G codes per line and it wasn't talking about M codes.
    Dec 2010
    24
    You're correct, I can have multiple G codes per line, but only one M code per line.
    Forgive me, I'm still trying to get use to this whole CAM software thing. Normally, programming at the machine, I can only enter one G per event and each event is a line.
    Also, your suggestion worked on changing g41 to g01. And moving g41 back one line. Thanks for your help
  1. G19 Cutter Comp
    By smaida10 in forum G-Code Programing
    Last Post: 02-24-2010, 03:09 PM
  2. cutter comp help please!
    By metlcutr55 in forum G-Code Programing
    Last Post: 02-25-2009, 02:50 PM
  3. Cutter comp on an id hole< cutter diam.??
    By PaintItBlue in forum Haas Mills
    Last Post: 05-06-2008, 12:30 AM
  4. ProtoTRAK freezing up after cutter comp error with g-code
    By LancoUSA in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-24-2007, 03:12 AM
  5. cutter comp error
    By mikeh78 in forum Haas Mills
    Last Post: 04-21-2006, 06:04 PM
