603,850 active members*
4,711 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Machining L168 aluminum
Results 1 to 3 of 3
    49
    Question Machining L168 aluminum
    I need to mill a piece of aluminum graded L168 aircraft grade stuff,3/4" thick. Need chart of SFM for HSS and Carbide tools please.
    Oct 2004
    107
    I believe it is similar to 2014 aircraft grade aluminum. I would start right around 400sfm-1000sfm depending on cutter and then a chip load sutable for the cutter such as .001 for a 1/8" end mill 900sfm, .003 for a .25 end mill about 600 sfm, .08 for a .75 rougher and 400 sfm. Then just tweek it to your particular machine / and cuttin conditions. You also need to address pockets differently than side milling etc. I would go to the companies web site who makes your tooling and see what they recomend as they are all a little different. Hope that helps. :cheers:
    49
    thanx for the help,I well be sure to try these and i will check with our supplier
  1. Machining Aluminum Bronze
    By home-tek in forum Material Machining Solutions
    Last Post: 12-30-2006, 06:06 AM
  2. Question about machining aluminum
    By mustbenu in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2005, 02:41 AM
  3. Machining 2219-t4 aluminum
    By scottwally in forum MetalWork Discussion
    Last Post: 06-19-2005, 04:53 AM
  4. CNC Aluminum
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 02-12-2005, 04:39 PM
  5. machining aluminum castings
    By donj1 in forum MetalWork Discussion
    Last Post: 11-05-2004, 01:12 PM
