603,942 active members*
4,228 visitors online*
Results 1 to 3 of 3
    Feb 2005
    303
    Storing / Retrieving a letter in a variable?
    I am writing a series of subprograms to track tool life and wear offset adjustments over the course of several long-running jobs.
    One of the subprograms will output (via DPRNT) the collected data on a regular basis; this subprogram is generic and can be called from any part programs as required.
    The part program will store the part number, job number, etc as variables which the reporting subprogram can use when it generates its output.
    What I would *like* to do is also be able to output the drawing revision.
    Some of our customers use a numeric system for drawing revisions, which is no trouble at all to store/retrieve.
    However, a large number of our customers use letters... e.g. "REV D".
    I have not been able to figure out a way to handle this.
    Section from part program:
    #599=2137649(PART NUMBER)
    #598=20(SEQ NUMBER)
    #596=134558.09(JOB/LOT NUMBER)
    Subprogram segment:
    DPRNT[PART NUMBER #599[80] REV NO ????[20]]
    DPRNT[JOB NO #596[52] SEQ NO #598[40]]
    DPRNT[MACHINE NUMBER #6026[80]]
    2932
    Something to mull over...
    You could possibly store a number from 1 to 26, then use that value to pick one of several DPRNT statements.
    IF[#20EQ1]GOTO1001(A)
    IF[#20EQ2]GOTO1002(B)
    IF[#20EQ26]GOTO1026(Z)
    (START OF LETTERS)
    N1000(NO REV)
    DPRNT[PART NUMBER #599[80]]
    GOTO1027
    N1001(A)
    DPRNT[PART NUMBER #599[80] REV NO A]
    GOTO1027
    N1002(B)
    DPRNT[PART NUMBER #599[80] REV NO B]
    GOTO1027
    N1026(Z)
    DPRNT[PART NUMBER #599[80] REV NO Z]
    N1027(REMAINING DPRNTS)
    Feb 2005
    303
    Thank you, dcoupar. That was what I figured the answer would be; just thought I'd pick the brains here.
  1. Retrieving TNC 145 via serial connection
    By A.A in forum Bridgeport / Hardinge Mills
    Last Post: 03-20-2009, 02:07 PM
  2. Retrieving Storing Status of G41/G42 in VB Script
    By Mr. Technical in forum Mach Wizards, Macros, & Addons
    Last Post: 06-02-2008, 07:31 PM
  3. EMC2 variable pitch / variable diameter threading.
    By samco in forum MetalWork Discussion
    Last Post: 03-09-2008, 07:40 PM
  4. retrieving files?
    By bearracecars in forum Autodesk
    Last Post: 09-17-2007, 04:34 PM
  5. Retrieving Stepper Motors
    By andy_ck87028 in forum Stepper Motors / Drives
    Last Post: 10-25-2005, 10:42 PM
