603,365 active members*
3,810 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Autodesk Inventor and Mechanical Questions
    Aug 2006
    74
    Has anybody had problems with dxf in sheetcam, can't seem to get a simple part to even show up.
    Chip
    Chip Coale
    Jan 2004
    105
    Quote Originally Posted by coalstove View Post
    Chip
    Just bought SheetCam, so haven't used it much. But, what dxf version are you exporting? Maybe try something "older", i.e. a smaller version number.
    Monte
    Apr 2007
    148
    I use Sheet Cam for all our mill programing, try saving your drawing in
    2000dxf format. Then in sheetcam you go to file and then open drawing, it should show up.
    Jan 2006
    7
    This works for Inventor
    Create your part in a sheetmetal .ipt>
    Finish the sketch and face the part>
    Convert to a Flat Pattern>
    Right click on the flat pattern icon in the browser menu>
    Go to Save copy as and save it as a .dxf>
    The .dxf file can then be opened into SheetCAM.
  1. Mastercam and Autodesk Inventor
    By Bartsimsonii in forum Mastercam
    Last Post: 11-23-2007, 10:27 PM
  2. AutoDesk Inventor
    By jrotruck in forum Solidworks
    Last Post: 08-22-2007, 05:07 AM
  3. Autodesk Inventor LT ***** Free Version*****
    By just_lkn in forum Autodesk
    Last Post: 05-23-2007, 01:34 PM
  4. The power of Autodesk Inventor
    By sanddrag in forum Uncategorised CAM Discussion
    Last Post: 06-06-2006, 03:08 PM
  5. Any Autodesk Inventor 8 users here?
    By Spinnetti in forum Uncategorised CAM Discussion
    Last Post: 03-17-2004, 01:05 PM
