603,326 active members*
3,530 visitors online*
Results 1 to 7 of 7
    Oct 2008
    1147
    How do you home an A axis?
    After I build my next Z axis, I'd really like to build a Z axis mounted 4th axis. I'm thinking in this situation it's called an A axis. Anyways, I'm sketching out some ideas but I'm stumped on how you would home it. Since it'll rotate left and right, I wouldn't be able to use the cheapo homeing lever switch I use now for my x, y, and z since as it would run over it. I've thought about a detachable hard stop but I'm sure something much better has been done.
    I've read through some 4th axis builds but I havn't seen anything about homeing it. Can someone enlighten me?
    Also I notice a lot of 4th axis's use servos and not steppers. Any particular reasons?
    the magic of servos is the use of encoders
    what about using a proximity switch , this guy sells them pretty cheap http://cgi.ebay.com/CNC-Proximity-Li...4.c0.m14.l1262
    he's great to deal with , i've bought a fair bit of his stuff
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Feb 2007
    4550
    Post
    FandZ,
    I use these on all my axis including the rotary, they work really well.
    http://www.hamlin.com/specsheets/591...;20IssueAc.pdf
    http://tinyurl.com/nn8bsq
    59140-040-ND
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    35494
    A push button switch with a two sided ramp to activate it. The ramp can go past the switch without damaging it.
    Jul 2008
    390
    Quote Originally Posted by FandZ View Post
    Oh geez FandZ. What are you getting into now?
    Just kidding. Can't wait to see what you are up to.
    Oct 2008
    1147
    Thanks for the links and replies fellas. It was just one of those nagging questions that had to be asked. I guess what I'll do is keep designing it and use what ever fits the design best. Glad to know it doesn't have to be too much of an exotic solution.
    Oct 2008
    1147
    Quote Originally Posted by amishx64 View Post
    I think it's the natural progression of building a cnc. But you know me, always looking for new ways to use up this stock pile of skate bearings I have left over.
  1. EMC won't recognize home on Y axis
    By DustToDust in forum LinuxCNC (formerly EMC2)
    Last Post: 09-25-2009, 06:09 PM
  2. What is the gcode to ref 1 axis home after
    By seanreit in forum Uncategorised MetalWorking Machines
    Last Post: 12-07-2008, 11:18 PM
  3. Eztrak X axis will not home
    By sidstover in forum Bridgeport / Hardinge Mills
    Last Post: 11-12-2008, 02:04 AM
  4. Z-axis 0 point (home) ?
    By tvdbon in forum DIY CNC Router Table Machines
    Last Post: 05-26-2008, 08:05 PM
  5. Z axis Home backoff
    By Stevie in forum Mach Mill
    Last Post: 12-21-2005, 12:28 AM
