603,342 active members*
3,106 visitors online*
Results 1 to 4 of 4
    Mar 2006
    33
    Z-axis 0 point (home) ?
    Hi There,
    I've got a rockcliff machine up and running and done some basic stuff. I'm currently in the process of putting on some limit/home switches, but one thing that I've always wondered is whether the 0 point of the z-axis should be on the table or on the workpiece ? So far I always had the 0 point on the workpiece and then I modifed my g-code to travel the z axis into the minus. Example if I wanted to make a 1mm cut deep then I would tell it to go to Z-1.0000
    Is this the right way? How does it usually work on cnc machines ?
    Mar 2006
    427
    I have my zero/home at the way up so that when I want to do a tool change I just goto home. Then I do a touchoff and set up my work piece. Its just me but in a homing event I dont like things moving towards the table.
    Mar 2003
    35494
    Quote Originally Posted by tvdbon View Post
    Yes. that's the right way. 0 is the top of the workpiece. What are you creating your code with that you need to modify it? Pretty much all CAM programs write code with Z- moving down into the work, although most will give you the option to do it differently.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2006
    33
    So far I have only used lazycam. But I'm still learning it so I haven't done more than load a picture, post the gcode, modify z and then cut it. Nothing great yet, but I'm still learning. So I guess the best would be to have my z-axis home in at the highest possible z value.
    Thanks guys, thats what I suspected but I wanted to check with experts first
  1. Busellato Optima Point To point
    By Malacara in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-12-2007, 01:22 AM
  2. Z Axis Starting Point in DCAD Execute/Simulation
    By jim_stoll in forum Dolphin CAD/CAM
    Last Post: 09-16-2007, 08:08 AM
  3. converting point to point programs
    By kevinwd1 in forum Uncategorised CAM Discussion
    Last Post: 06-11-2007, 05:45 PM
  4. Home, zero, starting point...
    By saturnnights in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-14-2006, 09:57 PM
  5. Z axis Home backoff
    By Stevie in forum Mach Mill
    Last Post: 12-21-2005, 12:28 AM
