587,833 active members*
4,259 visitors online*
Results 1 to 6 of 6
    Convert MT-2 to MT-3 or R8
    I have a LMS KX1 mill which has a MT-2 taper spindle. I would like to build an ATC using the TTS tooling so I need to have a R8 or MT-3 taper spindle.
    Does anyone know whether it is possible (and how) to change the spindle on my KX1 to something compatible with TTS tooling?
    David
    Mar 2008
    3655
    Cut your losses now, sell the KX1 and get a larger mill like maybe the Novakon NM-35.
    CR.
    Hi CR,
    I do have a Novakon NM-135 coming in December, but I was thinking of keeping the KX1 to "experiment" with.
    David
    Mar 2008
    3655
    Quote Originally Posted by David Da Costa View Post
    Hi CR,
    David
    You have already outgrown the KX1-whether you realize it or not. Adding money to try to make this small machine into something it is not, is just going to lose you money that would apply to purchasing the inevitable larger machine.
    Not only that, but your upgrade efforts MIGHT even reduce resale value.
    CR.
    Mar 2008
    3655
    Ok, I was answering the original question before you edited it. If you can afford to experiment with KX1 then by all means--Enjoy!
    CR.
    Hey David, sent you a private message.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  1. osp -convert
    By phx in forum Okuma
    Last Post: 10-11-2011, 12:55 PM
  2. Convert 440 3ph to 220 3ph
    By jstrayer in forum Community Club House
    Last Post: 12-28-2007, 04:44 AM
  3. Can I convert this?
    By Crazy Phantom in forum Benchtop Machines
    Last Post: 12-13-2005, 06:47 AM
  4. I'm a new convert
    By Stevie in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2005, 01:46 AM
  5. How did you convert
    By cncadmin in forum Benchtop Machines
    Last Post: 03-18-2003, 04:42 PM
