There is no standard between different machines using the same motors and drives.
It is not necessarily your rapid traverse rate, (G00), but the acceleration.
The motors and any reduction should be designed around the desired acceleration this depends on the inertia of the load.
As has been previously mentioned, you most likely will have to adjust both accel and max rapids.
Al.
Albert E.
