587,997 active members*
1,877 visitors online*
    Nov 2009
    26
    I Need Some Spindle Bearing Grease!
    I'm getting ready to replace the spindle bearings in my DynaMyte 2400 mill (10K rpm spindle) and I need a small amount (< 10cc) of grease for the new bearings.
    I thought the bearings would be prelubed, but have since learned that they have only a light coating of protectant.
    The lubricants listed below are all compatible with my needs.
    If anyone has some leftover from a bearing job I would greatly appreciate hearing from you!
    Barden G-75
    Timken Ultra High Speed Spindle Grease
    Kuberspeed BF 72-22
    FAG Arconal L-75
    FAG Arconal Speed 2.6
    Lubecon High Speed L252
    SKF LGCT 2
    Thanx,
    Rex
    rode2rouen (at) yahoo (dot) com
    15362
    bjorn toulouse
    You can get the Kubler from most good bearing suppliers, There is normally not much left over as it comes in a small tube
    Mactec54
    Feb 2009
    6028
    Get klubber NBU15. All world should have it, and good bearing houses will to. It comes in a small tube, about 15 bucks. Enough to do that spindle 5 times. Too much grease creates heat and damage new bearings. NBU is used on every high speed spindle I've ever done, and that's quite a few.
    High Speed Spindle Grease - Kluber Alternative
    Quote Originally Posted by underthetire View Post
    You are right Kluber NBU 15 is the ideal spindle grease. The downside is it is very expensive and sometimes hard to source. We are Brit-Lube a UK based specialist grease mfr. We have a direct alternative to NBU 15 - our grease High Speed DN Plus. They are very similar in formulation and performance. We can save you 50% on your Kluber prices and can ship anywhere worldwide swiftly.
    Home - Brit-Lube email: [email protected] for Data Sheet & Price..
  1. Grease Zerk For THK bearing block.
    By Mcyoda in forum Linear and Rotary Motion
    Last Post: 08-23-2008, 05:57 AM
  2. Linear bearing grease
    By Claude Boudreau in forum Linear and Rotary Motion
    Last Post: 04-11-2008, 05:33 AM
  3. Which Bearing grease?
    By skyline in forum Linear and Rotary Motion
    Last Post: 04-15-2007, 08:10 PM
  4. Bearing Grease
    By georgebarr in forum DIY CNC Router Table Machines
    Last Post: 06-06-2005, 10:07 PM
  5. Spindle Grease ?
    By Willyb in forum Uncategorised MetalWorking Machines
    Last Post: 02-15-2005, 10:25 PM
