I am looking at buying a CNC router for wood and need some advice on what to buy. I'm a little overwhelmed with the variety of choices and am not sure what to get or where I can get what I need. I don't need alot of XY travel, a 2'x2' or a 2'x4' would be fine, but I would like to have about 12" of Z travel (or even 18" might be nice) which is way more than the traditional 5"-6" that I am seeing on most units. Budget is also an issue as I only have around 3k to spend on everything I need to get the machine running. I have alot of electrical and mechanical experience and probably could build it DIY, but I don't have the time, so I'm looking for either a ready to assemble kit or a finished machine. Also, Im looking at doing alot of 3D surface machining and was thinking about buying Vectric Cut3D. Is that a good choice, or is there a better (cheap) option for 3D surface milling?
Thanks for the help,
Corey
