Full Re-Retrofit On My Blog...
I Somehow Obtained a Actual Tormach Lathe BOB for My Retrofit...
Everything is Going Well I Have Full Accurate Movement, I had to Change Some Proximity Sensors From PNP to NPN homing and limits e-stop all working as they should..
My goal "almost there" is that with Path Pilot just a couple small edits to the INI File and updating should be simple when the Tormach updates roll out as well as adding a Turret in the future.
My Issue Right now is I Trying to Figure Out the VFD Configuration and Adapt to the Hitachi WJ200 to the Tormach BOB, Tormach Uses An Emerson Commander SK VFD.
The VFD Configuration is the next to the Last thing on my list for the Electrical Side.. Then after little over 3 years and multiple configurations I can Finally get things finished up.
Most the Connections Are Self Explanatory Hooking to the BOB Hitachi. Just trying to Figure How They are Using the Emerson I.O. for the Speed Control. (do not really want to assume and let the magic smoke out) It is hooked up on the lathe differently then the Mill or I would just go to my 1100 and pull the settings.
B1, B3, B7, On the Emerson Are In Question.
Ideal Help Would be to have someone with a Slant Lathe Pull Their Settings From The Emerson VFD for the I.O. (Thank You rdsi)
Manuals: SK Reference | SK Advanced | WJ200
Emerson = Hitachi
T1 = L Lower
T5 & T6 = N/A (This is an E=Stop if Closed Prob Will set it to Normally Open Alarm Relay AL0-AL1 on the Hitachi.)
B1 = ? See Below (Will Assume Will Go to O on the Hitachi but could be EA also)
B2 = P24
B3 = ? See Below
B4 = N/A (Drive Enable Tied to B2 24V Pins 9 & 10 on BOB)
B5 = 1 (Forward)
B6 = 2 (Reverse)
B7 = ? See Below (Solved EA) Set WJ200 A001 Frequency Source to 06 Pulse.
From the Emerson Manual
B1 Analog Voltage Output - Motor speed
Voltage Output 0 to +10V
Scaling 0V represents 0Hz/rpm output +10V represents the value in Pr 02 Maximum set speed
Maximum output current 5mA
Resolution 0.1%
B1 Tormach Setting
A Voltage proportional to output current again not sure how to translate that to Hitachi WJ200 settings .
B3 Digital Output - Zero Speed (or Digital Input)
Voltage Range 0 to +24V
Maximum Output Current 50mA at +24V (current source)
B3 Function Tormach Settings
N=0 Zero Speed ??? How does that Translate to Hitachi WJ200 settings.
B7 Digital Input - Local/Remote Speed Reference
Logic Positive
Voltage range 0 to +24V
Nominal threshold voltage +10V
B7 Function Tormach Settings
Fr Frequency input Using Pulse Train Setting and EA On Hitachi WJ200
BOB to Emerson VFD
WJ200
