587,082 active members*
2,758 visitors online*
Results 1 to 6 of 6
Threaded View
    Jul 2008
    RC Car Gearbox Casing
    I have an old 1/9 scale Kyosho Toyota 4 Runner - gas powered, which has a CCVT gearbox (really is a continuously variable transmission with Neutral, Forward speeds and Reverse).
    The transmission is mechanically shifted using a servo.
    However, due to the material used for the case (hard clear-ish plastic):
    1) It starts leaking at the feet (where it's attached to the chassis) because the screw holes crack
    2) The top post where the shift linkage is mounted breaks because the post is plastic and it breaks over time.
    I'm thinking of coming up with a replica using aluminum. It would be stronger and would look way cool (anodized black maybe)
    Challenges are:
    1) A clear plastic/acrylic window on the side would be nice or a dipstick to measure the oil capacity
    2) The internal structure of the shell is pretty complicated
    The seal between the shells does not have to be fancy, we could just use RTV gasket maker
    Attached are some pictures, I will post more details later.
    You can see that in this picture, the top post is already broken.
    Please let me know what you think about this idea. I had taken a class in CAD design (using Pro E) so I could do some of the design if I can get my hands on a CAD software.
  1. 90° Beveled Gearbox ?
    By twocik in forum MetalWork Discussion
    Last Post: 06-21-2008, 08:20 AM
  2. Arched casing
    By dannyu in forum WoodWorking Topics
    Last Post: 03-05-2008, 03:15 PM
  3. Check ZX7045 GearBox
    By fcollebluegate in forum Charter Oak Automation Support Forum
    Last Post: 08-31-2007, 08:34 AM
  4. Rfq Acrylic Casing For Electronics (Awarded)
    By naspc in forum Employment Opportunity
    Last Post: 05-30-2007, 10:49 PM
  5. RF 45 gearbox problem need help please
    By fc911c in forum Benchtop Machines
    Last Post: 01-12-2007, 11:56 PM
