17-4PH is a very strong stainless steel. Please quote for quantity of 4.
It isn't importing correctly with my CAM program.
Do you have a solid model of it?
Apparently I don't know anything, so please verify my suggestions with my wife.
No he doesn't, but that file you took a screenshot of is how it's supposed to look. All the dimensions are there to quote off of. I know I messed with it for a very little bit of time trying to generate toolpath and there is broken lines, doubles, strings, and geometry on diferent z axes bounds. It's a mess but it's good enough to quote off of.
Is this what it is supposed to be? Is it from bar stock or a block, do you supply the material? Is there a bore in the center? I would need a print or a solid model to give you an accurate quote. Most places would just quote high - more of a guess - but I will toolpath it and give an accurate quote that I would stick to.
I also need to know the tolerances and finish requirements to give an accurate quote.
Yes, that's how it's susposed to look, but with a 3/8 hole through the center. The tolerance would only need to be high if low tolerance would cause it to be unbalanced, it will rotate at high rpms. Use standard tolerance for the quote.
So far the lowest quote I got without material included, is $320, just to let you know. Thank you.
