587,836 active members*
5,230 visitors online*
Results 1 to 9 of 9
    Feb 2012
    Mori nv5000 will not boot
    while trying to boot my mori mill nv5000 it booted to
    BUSREADY......
    OK
    It then just sits there and will not go any further, while rebooting many times the screen said.
    Goplib.DLL : dosopen failed 110
    [C:\Gop3]
    Any ideas. on how I can get my machine booted up so I can run it?
    Feb 2009
    6028
    Open rear of operator panel. Find small screw on top of CPU to remove small cover. With power off, eject the PCMCIA card on top of CPU. Re-insert PCMCIA card and try powering up.
    Feb 2012
    I tried reinserting the card but the machine is frozen at
    BUSREADY
    OK....
    Feb 2009
    6028
    Sounds like the mapps software got corrupted, or the main board of the Fanuc has a problem. Look in the enclosure and see what number is on on the fanuc main board.
    Feb 2012
    8
    Feb 2009
    6028
    8=State where CPU is not started after power on(boot system). (main board may be faulty)
    Think you lost the Fanuc main board....
    Feb 2012
    I was afraid of that.....in-process of ordering a new one
    Feb 2009
    6028
    Ya, thats a fun one. Hope you have everything backed up. You will need to zero return the axis, magazine, and check tool height. If you get stuck, let me know, i should have an SRAM back up for a NV, just need to know if its a NV5000 Alpha or older NV5000, and what options.
    Feb 2012
    Thanks for your help...cpu was bad...back up and running
  1. Mori NV5000 Z-axis ref. adjustment
    By teal854t in forum Mori Seiki Mills
    Last Post: 11-01-2022, 12:03 PM
  2. mori nv5000 inverter alarm
    By Damnifiknow in forum Mori Seiki Mills
    Last Post: 09-04-2013, 07:11 PM
  3. Need Help on Mori Seiki NV5000
    By dannifer.ebot in forum Uncategorised MetalWorking Machines
    Last Post: 07-28-2010, 07:45 PM
  4. G08 on mori NV5000
    By Mill Guy in forum Mori Seiki Mills
    Last Post: 10-25-2008, 12:02 AM
  5. Mori NV5000 lost X,Y,Z,W zero reference
    By teal854t in forum Uncategorised MetalWorking Machines
    Last Post: 08-25-2007, 02:34 PM
