603,855 active members*
3,943 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > cheap quick change collet for 1/4 in UK?
Results 1 to 6 of 6
    Dec 2007
    93
    I saw a product called the "eliminator chuck" on youtube ([nomedia="http://www.youtube.com/watch?v=HDy0xeiq08g"]YouTube- Eliminator RC Quick Change Chuck Review[/nomedia])
    I haven't managed to find a UK supplier of even if they make a version for a 1/4 inch router.
    If anyone knows of a similar product that is cheap please make me aware of it.
    I have a Trend T4 router and the spindle thread is about 15mm diameter.
    Dec 2007
    93
    Even if there was a supplier abroad and it was chep enough I'd buy one.
    Perhaps there are other products similar to this that I dpn't know the names of
    Jan 2009
    57
    quick chuck
    I bought this one on EBAY from WIDGET for less than 16 USD.
    Rotozip 2610922300 Three Jaw Keyless Chuck
    It works great. Just have to watch that the ring doesn't rub on your work.
    Dec 2007
    93
    Thanks for the suggestion.
    Is it this one: http://www.widgetsupply.com/page/WS/...tozip/SFE5-RKC ?
    on that page they mention using a wrench to tighten the chuck.
    I don't quite understand how this works. Do you need to use a wrench to fix the router bit in securely, or do you tighten it by hand?
    Also can I ask what rotational speed you have run your at wothout trouble?
    Dec 2007
    93
    Ive just come across this http://www.sears.com/shc/s/p_10153_1...00#reviewsWrap
    which looks like it could be used in automatic tool changing, although I don't know if it's built for a 1/4 or 1/2 inch router
    Jan 2009
    57
    Quote Originally Posted by adamchapman View Post
    That is the one I have. I have run it at 30krpm with no problem. I haven't had to do more than hand tighten yet, but I have had to use the wrench to loosen.
  1. quick question about spindle face/r8 collet
    By 300sniper in forum Tormach Personal CNC Mill
    Last Post: 01-08-2009, 09:55 PM
  2. Need a quick answer on 3MT collet.
    By alexccmeister in forum Benchtop Machines
    Last Post: 10-19-2008, 03:57 PM
  3. Cheap Quick change router collet?
    By bigz1 in forum DIY CNC Router Table Machines
    Last Post: 05-16-2007, 12:57 AM
  4. Precision Quick change collet Set
    By thackman in forum Syil Products
    Last Post: 03-22-2007, 09:07 PM
  5. Quick change collet
    By MagTDK in forum DIY CNC Router Table Machines
    Last Post: 09-08-2006, 09:08 PM
