603,354 active members*
2,933 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Please rank the rigidity of these linear bearing options
Page 1 of 2 12
Results 1 to 20 of 32
    Mar 2011
    357
    I would like to know what the relative rigidity is of the following linear rail/bearing types and their pros and cons.
    CNCRP skate bearing
    V-bearings on steel angle ala Joes
    V-bearings on hardened v rails
    delrin wheels riding on 8020 ala openbuilds
    Round (SBR) rails
    profile rails (THK and HIWIN).
    Others?
    35494
    Re: Please rank the rigidity of these linear bearing options
    1 - profile rails (THK and HIWIN).
    The rest are a bit of a guess, and the machine construction can play a role in their stiffness.
    2a - Round (SBR) rails
    2b - V-bearings on hardened v rails
    3 - CNCRP skate bearing
    4 - V-bearings on steel angle ala Joes
    5 - delrin wheels riding on 8020 ala openbuilds
    Mar 2011
    357
    Thanks for the fast response Ger. You must live on this site.
    With regards to the X axis where MOST of the force on the rail is in the down direction(weight of the gantry) are round rails more viable if I want to save some money over option 1?
    May 2005
    3920
    Quote Originally Posted by tkms002 View Post
    With round rails you have to commit to spacing the bearings further apart due to the inherent looseness of round rail bearings. That means your rails need to be longer to end up with the same working area. Now given that in many cases people using profile rails will have them too close together. So it really is a matter of what you can get away for your design and what you are making. Round rail bearings generally have more clearance compared profile bearings thus need to be spaced farther apart. Also the round rail solutions are generally not as stiff as profile rails under load.
    One way to visualize this is too consider a pyramid with its base on the ground. Stable right, it resists tipping. Now imagin an upside down pyramid. Not so stable right? Many diy designs (gantry supports) are closer to an upside down pyramid than is ideal, this puts excess load on the bearings, and even profile bearings suffer though far less than round rail bearings. For round rail I’d look at triangles tha have long edge at 45 degree angle with respect to the base. With a high mounted gantry this can result in a very wide base.
    The other problem with round bearings is that they can rotate some around the linear rail. So your gantry supports need to be able to resist this small freedom of movement.
    Dec 2003
    1344
    We don't really have enough information to give answer other than in the most general terms since we don't know what kind of work the machine is intended for.The ranking given by ger21 is excellent and accurate.Clearly if you are intending to build a router for full size sheet materials the loads will be greater than for a laser operating over an area the size of a letter and this will affect what you may be able to make use of.
    35494
    During use, most of the forces on the gantry are in the horizontal direction, which translate into both up and down forces on the bearings.
    Mar 2011
    357
    Are you saying that because of a twisting force on the gantry? I can imagine of the router bit was stuck(worst case) and the Y or X motors were pushing it would cause a twisting moment on the X bearings. Is that what you are referring to?
    Mar 2011
    357
    Quote Originally Posted by wizard View Post
    My gantry plan is to have a short riser (maybe 3 inches or less) on the gantry and have a work surface that is below the X axis bearings maybe 3-6 inches.
    Like this
Name:	gantry support.jpg
    35494
    Just the forces from accelerating the gantry and cutting will impart a lifting force on one of the bearings.
    Personally, I don't think round rails should be used at all (for any machines), so I can't say they'd be more viable.
    Mar 2011
    357
    Got it
    Lots of people are using them but I appreciate your opinion.
    35494
    It always comes down to whether you want a good machine, or a cheap machine.
    Mar 2011
    357
    Ya I got you there.
    Any comments on the picture I posted above?
    I think having a lowered work surface rather and a raised gantry should be stronger, right?
    Jun 2011
    692
    Ya I got you there.
    Raising the rails and having short gantry risers has its advantages (saves moving mass,) but you still need to build the frame that the rail sits on strong or you'll just have flex there instead.
    A downside is it makes it a little tougher to get material into and out of the router.
    Mar 2011
    357
    Quote Originally Posted by skrubol View Post
    Thank you
    Mar 2011
    357
    OK you convinced me but that leaves 2 more questions.
    1. can square rails be butt joined so I dont have to ship 9 ft of rail?
    2. You point out automation overstock for these, where do they source their rails and parts? I have tried contacting them but the link fails.
    3. Have you ever tried the chinese options?
    35494
    1) Ideally, they should be ground so that the seam is perfect. But I think that CNCRP supplies unground joints for their machines.
    2) China. low-cost BLH linear guideways equivalent to Hiwin HG series of you
    3) No. I purchased their surplus Hiwin's before they ran out.
    Mar 2011
    357
    1. I will contact CNCRP to see how they do it and what issues they have.
    2. If these are Chinese is there a reason to buy them for $5-$600 when I can get "the same thing" from LINEARMOTIONBEARINGS for $300?
    3, Lucky for you, bad for me.
    Thanks again
    35494
    2) Having someone here in the states that stands behind their products is worth something. If you have problems, it's worth a lot.
    3) I still spent $1500. They were more expensive than the Chinese versions they sell now.
    Mar 2011
    357
    ya, I hear ya.
    Thanks again
    Feb 2005
    834
    And if you want Hiwins, automation4less.com has from what I can see pretty good prices on them.
Page 1 of 2 12
  1. Replies: 4
    Last Post: 06-15-2015, 01:20 PM
  2. Bearing options/design for small z-axis?
    By cnczoner in forum Linear and Rotary Motion
    Last Post: 07-14-2011, 05:11 AM
  3. Linear bearing options
    By Grogyan in forum 3D Printer / 3D Scanner Discussion
    Last Post: 04-06-2011, 12:56 PM
  4. Cost-Cutting Custom Bearing Options from PBC Linear
    By Pacific Bearing in forum News Announcements
    Last Post: 05-28-2010, 06:23 PM
  5. Linear bearing spacing & Sizing linear rails?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2004, 08:09 PM
