603,936 active members*
2,360 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G201 Adjustable Step?
Results 1 to 9 of 9
    Mar 2004
    500
    I was just wondering if the Gecko G201 supports adjustable steps. It says that the driver can handle 10 microsteps, but I'm not sure if it can go full step, half step, and all that.
    Also, what is the main difference between the G210 and the G201, is it that the G210 supports adjustable steps, and can go full and half step?
    Thank you very much for your help. :rainfro:
    35494
    No. 1/10 only.
    Yes. Full, half, 1/5 and 1/10.
    Mar 2004
    500
    So, do you think that it is worth it to put the extra moola for a G210 and have the adjustability?
    Thanks.
    35494
    Usually, the only reason to get a G210 is because your computer or software can't output steps fast enough for the G201. Your motors will run best at the 1/10 step setting, anyway.
    Mar 2004
    500
    Is that for any motor? Why would they run best at 1/10 and not 1/8 or full step or half step?
    Thank you very much.
    35494
    Generally, the more microsteps, the smoother the motor will run.
    Mar 2004
    500
    But don't you lose torque with microsteps?
    Thanks.
    35494
    A little bit, but you more than make up for it in smoothness, and the elimination of resonance problems.
    Mar 2004
    500
    I saw some articles that say that microstepping drastically reduces torque, is this true. I have heard it doesn't make much difference in torque aswell. Is this right?
    Thank you.
  1. Ametek motors and step down ratio
    By dowling177 in forum Servo Motors / Drives
    Last Post: 03-01-2005, 07:24 PM
  2. step angle question??
    By kywoodwrkr in forum DIY CNC Router Table Machines
    Last Post: 02-22-2005, 05:04 PM
  3. Dirction / Step lines!
    By bigal in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2005, 08:51 PM
  4. Have problems with G201 and printer port
    By Christian in forum Gecko Drives
    Last Post: 09-26-2004, 08:44 PM
  5. Choosing a step rate?
    By Rhodan in forum CNC Machine Related Electronics
    Last Post: 04-26-2004, 03:42 PM
