587,307 active members*
3,713 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Help toolpath problem
Results 1 to 2 of 2
    Jan 2008
    5
    Angry Help toolpath problem
    I have used the "Contour Toolpath", "Rotation Axis", "Axis Substitution" and "Substitute Y axis" for machining before, there is no problem.
    Now because the work piece's diameter is too big, I therefore must face the work piece axle center to Z axis and uses aggerate head to let the cutting tool's direction as right side view for machining, but there is a problem that the axis substitution has not substituted for the Z axis. Is there any solution for this problem?
    Sep 2007
    217
    Look no emastercam I put the answer over there as well. You need to change the rotary axis in the machine definition manger to be rotating around the Z axis not the X axis if you want the ability to use the Z for axis mapping. If your axis is rotating around X then you will not have the option to use Z only X and Y since that is the only 2 available axis for that set-up anyway.
  1. HELP Mastercam X2 toolpath problem
    By cam168 in forum Mastercam
    Last Post: 01-16-2008, 07:59 AM
  2. V9 Toolpath Problem
    By Clawsie Machine in forum Mastercam
    Last Post: 12-01-2007, 08:34 AM
  3. Toolpath set up?
    By Jessica in forum ArtCam Pro
    Last Post: 03-13-2007, 05:13 PM
  4. 3D toolpath help
    By Dfennell in forum BobCad-Cam
    Last Post: 02-03-2007, 08:13 AM
  5. DeskCNC Toolpath problem
    By epineh in forum CNC Machine Related Electronics
    Last Post: 12-19-2006, 10:38 AM
