603,943 active members*
3,190 visitors online*
IndustryArena Forum > CAM Software > Mastercam > V9 Toolpath Problem
Page 1 of 2 12
Results 1 to 20 of 21
    Sep 2005
    84
    V9 Toolpath Problem
    I do a lot of machine with endmills to open up a hole from imperial to metric sizes since I do not have a lot of metric tools. I just recently got a new customer that is mostly metric. No problem, I drill the hole, then open them up with a endmill for the hole and SHCS. Tolerance for these are +-.005" INCH. That's why I do this. Now here's the problem.
    I choose an arc, "toolpath", "contour", "chain", pick the arc with CLIMB milling direction. Choose a 1/2" endmill and choose "ramp" for contour type. I usually choose say .05" by depth. This was fine for circular Interpolation. Cutter would just run counter clockwise to depth, and at depth do one more arc to flatten the bottom of the contour.
    BUT
    Now it will do down the .05" in a Counter clockwise arc, then the next .05" it will run in a CLOCKWISE motion? It will keep going back and forth for the total depth. Just doesn't leave a nice finish as the start point seems to have a different size there? Code goes from "G3" to "G2" back to "G3" and so on? It has never done that till today, so any ideas?
    Thanks, John
    Sep 2007
    49
    Sounds like your arc is incomplete or your start pt. and end pt. are not connected.
    Apr 2003
    3578
    Please send or attach your file sample so I can review sounds like you are chaining the wrong way. you do know by what direction you pick were it will cut keeping the tool to the left and CCW being climbing at all times.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Nov 2007
    363
    your problem is version 9 .You need to get X2 it has more details on things like this you should get it or at least try the demo @ MastercamX2.com
    Best Regard,
    Michael82
    Apr 2003
    3578
    I agree that MCX2 would be an improvment but that alone would not fix the issue at hand.
    Cadcam
    Sep 2005
    84
    I will post the file on Sunday. This is the first time in 10 years that this has happen to me where I thought something was "toggled on"? But I couldn't find anything???
    Apr 2003
    3578
    Sounds good look for it tommorow.
    Cadcam
    Sep 2005
    84
    OK, sorry for the delay, but here it is:
    Parameters are, .020" above part to start, Helical ramp down to -.513
    When I choose "ramp", DEPTH clicked Ramp depth .050. That's it.
    This is just part of it.
    If you like, PM me an email addy, and I will send the MC9 file and data so you can see the whole deal.
    Thank, John
    :rainfro:
    (MSG, 1/2" E'MILL )
    :T5 M6
    N180 M1
    N182 G0 G90 X1.426 Y.0006 S2500 M3
    N184 Z1.
    N186 Z.02
    N188 G1 X1.4255 Y.0112 Z.0194 F25.
    N190 X1.4243 Y.0218 Z.0188
    N192 X1.4224 Y.0323 Z.0183
    N194 X1.4196 Y.0426 Z.0177
    N196 X1.4162 Y.0526 Z.0171
    N198 X1.412 Y.0624 Z.0165
    N200 X1.407 Y.0719 Z.0159
    N202 X1.4015 Y.081 Z.0153
    N204 X1.3952 Y.0896 Z.0148
    N206 X1.3884 Y.0978 Z.0142
    N208 X1.381 Y.1054 Z.0136
    N210 X1.373 Y.1125 Z.013
    N212 X1.3645 Y.119 Z.0124
    N214 X1.3556 Y.1249 Z.0119
    N216 X1.3463 Y.1301 Z.0113
    N218 X1.3367 Y.1345 Z.0107
    N220 X1.3267 Y.1383 Z.0101
    N222 X1.3165 Y.1414 Z.0095
    N224 X1.3061 Y.1437 Z.009
    N226 X1.2955 Y.1452 Z.0084
    N228 X1.2849 Y.1459 Z.0078
    N230 X1.2742 Z.0072
    N232 X1.2636 Y.1451 Z.0066
    N234 X1.2531 Y.1435 Z.006
    N236 X1.2427 Y.1412 Z.0055
    N238 X1.2325 Y.1381 Z.0049
    N240 X1.2225 Y.1342 Z.0043
    N242 X1.2129 Y.1297 Z.0037
    N244 X1.2036 Y.1244 Z.0031
    N246 X1.1947 Y.1185 Z.0026
    N248 X1.1863 Y.112 Z.002
    N250 X1.1784 Y.1049 Z.0014
    N252 X1.171 Y.0972 Z.0008
    N254 X1.1642 Y.089 Z.0002
    N256 X1.158 Y.0803 Z-.0003
    N258 X1.1525 Y.0712 Z-.0009
    N260 X1.1477 Y.0617 Z-.0015
    N262 X1.1435 Y.0519 Z-.0021
    N264 X1.1401 Y.0418 Z-.0027
    N266 X1.1374 Y.0315 Z-.0033
    N268 X1.1355 Y.021 Z-.0038
    N270 X1.1343 Y.0104 Z-.0044
    N272 X1.134 Y-.0003 Z-.005
    N274 X1.1344 Y-.0109 Z-.0056
    N276 X1.1356 Y-.0215 Z-.0062
    N278 X1.1375 Y-.032 Z-.0067
    N280 X1.1402 Y-.0423 Z-.0073
    N282 X1.1437 Y-.0524 Z-.0079
    N284 X1.1479 Y-.0622 Z-.0085
    N286 X1.1528 Y-.0717 Z-.0091
    N288 X1.1583 Y-.0807 Z-.0097
    N290 X1.1646 Y-.0894 Z-.0102
    N292 X1.1714 Y-.0976 Z-.0108
    N294 X1.1788 Y-.1052 Z-.0114
    N296 X1.1867 Y-.1123 Z-.012
    N298 X1.1952 Y-.1189 Z-.0126
    N300 X1.2041 Y-.1247 Z-.0131
    N302 X1.2134 Y-.1299 Z-.0137
    N304 X1.223 Y-.1344 Z-.0143
    N306 X1.233 Y-.1382 Z-.0149
    N308 X1.2432 Y-.1413 Z-.0155
    N310 X1.2536 Y-.1436 Z-.016
    N312 X1.2642 Y-.1451 Z-.0166
    N314 X1.2748 Y-.1459 Z-.0172
    N316 X1.2854 Z-.0178
    N318 X1.2961 Y-.1451 Z-.0184
    N320 X1.3066 Y-.1435 Z-.019
    N322 X1.317 Y-.1412 Z-.0195
    N324 X1.3272 Y-.1381 Z-.0201
    N326 X1.3372 Y-.1343 Z-.0207
    N328 X1.3468 Y-.1298 Z-.0213
    N330 X1.3561 Y-.1246 Z-.0219
    N332 X1.365 Y-.1187 Z-.0224
    N334 X1.3734 Y-.1122 Z-.023
    N336 X1.3814 Y-.1051 Z-.0236
    N338 X1.3888 Y-.0974 Z-.0242
    N340 X1.3956 Y-.0892 Z-.0248
    N342 X1.4018 Y-.0805 Z-.0253
    N344 X1.4073 Y-.0714 Z-.0259
    N346 X1.4122 Y-.0619 Z-.0265
    N348 X1.4164 Y-.0521 Z-.0271
    N350 X1.4198 Y-.042 Z-.0277
    N352 X1.4225 Y-.0317 Z-.0283
    N354 X1.4244 Y-.0212 Z-.0288
    N356 X1.4256 Y-.0106 Z-.0294
    N358 X1.426 Y0. Z-.03
    N360 G3 X1.421 Y.005 P.005
    N362 G1 X1.426 Y0.
    N364 X1.4256 Y-.0106 Z-.0306
    N366 X1.4244 Y-.0212 Z-.0312
    N368 X1.4225 Y-.0317 Z-.0317
    N370 X1.4198 Y-.042 Z-.0323
    N372 X1.4164 Y-.0521 Z-.0329
    N374 X1.4122 Y-.0619 Z-.0335
    N376 X1.4073 Y-.0714 Z-.0341
    N378 X1.4018 Y-.0805 Z-.0347
    N380 X1.3956 Y-.0892 Z-.0352
    N382 X1.3888 Y-.0974 Z-.0358
    N384 X1.3814 Y-.1051 Z-.0364
    N386 X1.3734 Y-.1122 Z-.037
    N388 X1.365 Y-.1187 Z-.0376
    N390 X1.3561 Y-.1246 Z-.0381
    N392 X1.3468 Y-.1298 Z-.0387
    N394 X1.3372 Y-.1343 Z-.0393
    N396 X1.3272 Y-.1381 Z-.0399
    N398 X1.317 Y-.1412 Z-.0405
    N400 X1.3066 Y-.1435 Z-.041
    N402 X1.2961 Y-.1451 Z-.0416
    N404 X1.2854 Y-.1459 Z-.0422
    N406 X1.2748 Z-.0428
    N408 X1.2642 Y-.1451 Z-.0434
    N410 X1.2536 Y-.1436 Z-.044
    N412 X1.2432 Y-.1413 Z-.0445
    N414 X1.233 Y-.1382 Z-.0451
    N416 X1.223 Y-.1344 Z-.0457
    N418 X1.2134 Y-.1299 Z-.0463
    N420 X1.2041 Y-.1247 Z-.0469
    N422 X1.1952 Y-.1189 Z-.0474
    N424 X1.1867 Y-.1123 Z-.048
    N426 X1.1788 Y-.1052 Z-.0486
    N428 X1.1714 Y-.0976 Z-.0492
    N430 X1.1646 Y-.0894 Z-.0498
    N432 X1.1583 Y-.0807 Z-.0503
    N434 X1.1528 Y-.0717 Z-.0509
    N436 X1.1479 Y-.0622 Z-.0515
    N438 X1.1437 Y-.0524 Z-.0521
    N440 X1.1402 Y-.0423 Z-.0527
    N442 X1.1375 Y-.032 Z-.0533
    N444 X1.1356 Y-.0215 Z-.0538
    N446 X1.1344 Y-.0109 Z-.0544
    N448 X1.134 Y-.0003 Z-.055
    N450 X1.1343 Y.0104 Z-.0556
    N452 X1.1355 Y.021 Z-.0562
    N454 X1.1374 Y.0315 Z-.0567
    N456 X1.1401 Y.0418 Z-.0573
    N458 X1.1435 Y.0519 Z-.0579
    N460 X1.1477 Y.0617 Z-.0585
    N462 X1.1525 Y.0712 Z-.0591
    N464 X1.158 Y.0803 Z-.0597
    N466 X1.1642 Y.089 Z-.0602
    N468 X1.171 Y.0972 Z-.0608
    N470 X1.1784 Y.1049 Z-.0614
    N472 X1.1863 Y.112 Z-.062
    N474 X1.1947 Y.1185 Z-.0626
    N476 X1.2036 Y.1244 Z-.0631
    N478 X1.2129 Y.1297 Z-.0637
    N480 X1.2225 Y.1342 Z-.0643
    N482 X1.2325 Y.1381 Z-.0649
    N484 X1.2427 Y.1412 Z-.0655
    N486 X1.2531 Y.1435 Z-.066
    N488 X1.2636 Y.1451 Z-.0666
    N490 X1.2742 Y.1459 Z-.0672
    N492 X1.2849 Z-.0678
    N494 X1.2955 Y.1452 Z-.0684
    N496 X1.3061 Y.1437 Z-.069
    N498 X1.3165 Y.1414 Z-.0695
    N500 X1.3267 Y.1383 Z-.0701
    N502 X1.3367 Y.1345 Z-.0707
    N504 X1.3463 Y.1301 Z-.0713
    N506 X1.3556 Y.1249 Z-.0719
    N508 X1.3645 Y.119 Z-.0724
    N510 X1.373 Y.1125 Z-.073
    N512 X1.381 Y.1054 Z-.0736
    N514 X1.3884 Y.0978 Z-.0742
    N516 X1.3952 Y.0896 Z-.0748
    N518 X1.4015 Y.081 Z-.0753
    N520 X1.407 Y.0719 Z-.0759
    N522 X1.412 Y.0624 Z-.0765
    N524 X1.4162 Y.0526 Z-.0771
    N526 X1.4196 Y.0426 Z-.0777
    N528 X1.4224 Y.0323 Z-.0783
    N530 X1.4243 Y.0218 Z-.0788
    N532 X1.4255 Y.0112 Z-.0794
    N534 X1.426 Y.0006 Z-.08
    N536 G2 X1.421 Y-.0045 P.005
    N538 G1 X1.426 Y.0006
    N540 X1.4255 Y.0112 Z-.0806
    N542 X1.4243 Y.0218 Z-.0812
    N544 X1.4224 Y.0323 Z-.0817
    N546 X1.4196 Y.0426 Z-.0823
    N548 X1.4162 Y.0526 Z-.0829
    N550 X1.412 Y.0624 Z-.0835
    N552 X1.407 Y.0719 Z-.0841
    N554 X1.4015 Y.081 Z-.0847
    N556 X1.3952 Y.0896 Z-.0852
    N558 X1.3884 Y.0978 Z-.0858
    N560 X1.381 Y.1054 Z-.0864
    N562 X1.373 Y.1125 Z-.087
    N564 X1.3645 Y.119 Z-.0876
    N566 X1.3556 Y.1249 Z-.0881
    N568 X1.3463 Y.1301 Z-.0887
    N570 X1.3367 Y.1345 Z-.0893
    N572 X1.3267 Y.1383 Z-.0899
    N574 X1.3165 Y.1414 Z-.0905
    N576 X1.3061 Y.1437 Z-.091
    N578 X1.2955 Y.1452 Z-.0916
    N580 X1.2849 Y.1459 Z-.0922
    N582 X1.2742 Z-.0928
    N584 X1.2636 Y.1451 Z-.0934
    N586 X1.2531 Y.1435 Z-.094
    N588 X1.2427 Y.1412 Z-.0945
    N590 X1.2325 Y.1381 Z-.0951
    N592 X1.2225 Y.1342 Z-.0957
    N594 X1.2129 Y.1297 Z-.0963
    N596 X1.2036 Y.1244 Z-.0969
    N598 X1.1947 Y.1185 Z-.0974
    N600 X1.1863 Y.112 Z-.098
    N602 X1.1784 Y.1049 Z-.0986
    N604 X1.171 Y.0972 Z-.0992
    N606 X1.1642 Y.089 Z-.0998
    N608 X1.158 Y.0803 Z-.1003
    N610 X1.1525 Y.0712 Z-.1009
    N612 X1.1477 Y.0617 Z-.1015
    N614 X1.1435 Y.0519 Z-.1021
    N616 X1.1401 Y.0418 Z-.1027
    N618 X1.1374 Y.0315 Z-.1033
    N620 X1.1355 Y.021 Z-.1038
    N622 X1.1343 Y.0104 Z-.1044
    N624 X1.134 Y-.0003 Z-.105
    N626 X1.1344 Y-.0109 Z-.1056
    N628 X1.1356 Y-.0215 Z-.1062
    N630 X1.1375 Y-.032 Z-.1067
    N632 X1.1402 Y-.0423 Z-.1073
    N634 X1.1437 Y-.0524 Z-.1079
    N636 X1.1479 Y-.0622 Z-.1085
    N638 X1.1528 Y-.0717 Z-.1091
    N640 X1.1583 Y-.0807 Z-.1097
    N642 X1.1646 Y-.0894 Z-.1102
    N644 X1.1714 Y-.0976 Z-.1108
    N646 X1.1788 Y-.1052 Z-.1114
    N648 X1.1867 Y-.1123 Z-.112
    N650 X1.1952 Y-.1189 Z-.1126
    N652 X1.2041 Y-.1247 Z-.1131
    N654 X1.2134 Y-.1299 Z-.1137
    N656 X1.223 Y-.1344 Z-.1143
    N658 X1.233 Y-.1382 Z-.1149
    N660 X1.2432 Y-.1413 Z-.1155
    N662 X1.2536 Y-.1436 Z-.116
    N664 X1.2642 Y-.1451 Z-.1166
    N666 X1.2748 Y-.1459 Z-.1172
    N668 X1.2854 Z-.1178
    N670 X1.2961 Y-.1451 Z-.1184
    N672 X1.3066 Y-.1435 Z-.119
    N674 X1.317 Y-.1412 Z-.1195
    N676 X1.3272 Y-.1381 Z-.1201
    N678 X1.3372 Y-.1343 Z-.1207
    N680 X1.3468 Y-.1298 Z-.1213
    N682 X1.3561 Y-.1246 Z-.1219
    N684 X1.365 Y-.1187 Z-.1224
    N686 X1.3734 Y-.1122 Z-.123
    N688 X1.3814 Y-.1051 Z-.1236
    N690 X1.3888 Y-.0974 Z-.1242
    N692 X1.3956 Y-.0892 Z-.1248
    N694 X1.4018 Y-.0805 Z-.1253
    N696 X1.4073 Y-.0714 Z-.1259
    N698 X1.4122 Y-.0619 Z-.1265
    N700 X1.4164 Y-.0521 Z-.1271
    N702 X1.4198 Y-.042 Z-.1277
    N704 X1.4225 Y-.0317 Z-.1283
    N706 X1.4244 Y-.0212 Z-.1288
    N708 X1.4256 Y-.0106 Z-.1294
    N710 X1.426 Y0. Z-.13
    N712 G3 X1.421 Y.005 P.005
    N714 G1 X1.426 Y0.
    N716 X1.4256 Y-.0106 Z-.1306
    Jan 2006
    4396
    That looks like a major problem. This is what it looks like for those that do not have a back plotter. This if for an Acromatic Control right??
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Sep 2005
    84
    Files have been email to Cad-cam.
    Toby, your correct about the Acromatic controller. What's a back plotter???
    Apr 2003
    3578
    (What's a back plotter???) Sir go here and review this Editor that backplots this what I us along with Predators Full Varifacation softwares as I sell them to.
    Links: http://www.shopfloorautomations.com/cnceditor.php
    http://www.shopfloorautomations.com/vcnc.php
    Cadcam
    Jan 2006
    4396
    Quote Originally Posted by Clawsie Machine View Post
    I use Predator Virtual CNC, Predator Editor and NC Plot. My Predator Software is Licensed through BobCAD/CAM and NC Plot through Scott Martinez.
    I have to admit that these are extremely valuable tools for back plotting 3 and 4 Axis Mills and 2 Axis Lathes. With a little trickery you can Verify Multi-Tasking Lathes.
    Got to love Software
    Here aare a few things I am testing in Predator Virual CNC for 4 Axis machining. So far I have not been successful with building a complete CNC Mill but these are some simple parts with STL Fixtures.
    You can see more examples on my website at www.axiscncprogramming.com for Predator Virtual CNC, Predator Editor, and NC Plot.
    Attached Thumbnails Attached Thumbnails 4th axis simulation with stl stock and fixture2.jpg   4th axis simulation with stl stock and fixture3.jpg   4th axis simulation with stl stock and fixture.jpg
    Toby D.
    Schwarzwald
    Sep 2005
    84
    Cad-cam, I tried twice but it keeps bouncing the emails back saying there Undeliverable???
    Apr 2003
    3578
    John I got the file and the issue at hand is the geo redraw the dia and repick the chain and it will work fine. did you draw this file or someone else?
    If you dont see this let me know and I will get you how I am seeing this.
    Cadcam
    Cadcam
    Sep 2005
    84
    Sorry if you got it twice? I'll go and look at it. I do all my own drawings here and other shops for years, so what I did is just pick the center point, create the arc, dia, 0,0, OK? So don't know what happened.
    NEWS FLASH, FOUND IT
    . IF you zoom in, there is a break in the arc, so therefore it's not a full arc to follow. I dimensioned it, and the arc is 359.79 degrees???? WHY in the world I would lose .22 degrees is beyond me as I wasn't doing anything that would require that type of stuff in the last 6 months?
    I just re-drew the arc, and worked fine?????????????? Thank, just DO NOT know why this would happen, but I will know IF it does happen again what I have to do?
    I usually use the verify in MasterCam when I'm doing more technical stuff, but in this basic parts, I see no need.
    Sep 2005
    84
    Now I just need to figure out the DNC for this machine so I can run big files????
  17. #17
    Jan 2006
    4396
    www.ncplot.com if you want a back plotter plus DNC capabilities at a good price. Mastercam might already have one built in though but if you want to be able to use MC while in DNC mode that could be a problem.
    Toby D.
    Schwarzwald
  18. #18
    Apr 2003
    3578
    There is no Backplot of NC code in MC but the there is two diffrent ways of DNC one is using the Cimco editor and it can run while he programs.
    John what type of machine are you running?
    Cadcam
  19. #19
    Sep 2005
    84
    I have a Cinci Arrow 500 with the Vickers Acromatic 2100 controller. I have never used this or seen this controller before I bought the machine. So I haven't strayed to far off the beaten path so to speak with this as I know there is some concerns with the hard drive crashing. So I'm pretty green with this controller as I couldn't see fixing it for something stupid I did. therefore, I just use what I need/know, and if there is anything else that I need to do, I get on-line and ask those who are better on this controller.
    As for back-plotting, I just use "verify" or "backplot" from MasterCam as it's been pretty good so far. I have Cimcoe Edit, and how do I go about DNC-ing from there? I can transfer in and out, just haven't tried to DNC? But I do have some files that don't seem to go in to easily? Machine promps me with "can not read file"? It's been in there before, but lately it been happening more and more?
    John
  20. #20
    Aug 2005
    149
    Man you did all that in BOBCAD...I heard bobcad sucked...doesn't look like it to me is it easy t o learn? and what about horizontal programming?
Page 1 of 2 12
  1. Toolpath set up?
    By Jessica in forum ArtCam Pro
    Last Post: 03-13-2007, 05:13 PM
  2. 3D toolpath help
    By Dfennell in forum BobCad-Cam
    Last Post: 02-03-2007, 08:13 AM
  3. DeskCNC Toolpath problem
    By epineh in forum CNC Machine Related Electronics
    Last Post: 12-19-2006, 10:38 AM
  4. Toolpath question
    By COPO427 in forum Mastercam
    Last Post: 11-15-2006, 05:37 PM
  5. Picstep 4 Toolpath
    By elogicca in forum CNC Machine Related Electronics
    Last Post: 07-22-2006, 04:24 AM
