I had a dissucssion with the head of the cnc dept. at work today and he said that if you typed in the tool change command and have the tool # and the m code on the same line that on some fanuc controls it will freak out and just keep changing the same two tools over and over.I told him that I have been doing it the whole time that I have working there. He said it was only on some Fanuc controls not all of them. So I showed him that my machine did not do any thing but change tools when I put in the two codes on the same line just like this T1M6;then press insert,then cycle start. Is there any Fanuc controls that will not except these two codes on the same line?
This is the only machine that I have ran at this company I just started this job.Should I try it on the other machines or not ?
