588,231 active members*
4,203 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Experience with Tilting 4th Axis?
Results 1 to 3 of 3
    Jan 2013
    263
    Tormach sells this kit 31997 - 4th Axis kit - 8" Tilting Motorized Rotary Table - Freight Additional for the 1100
    I can't seem to find any real good info or videos on this tilting rotary table. It's obvious that without a tailstock you're not going to be able to hold anything too long with this so you're limited in work piece size when actually using the tilting. But other than that can anyone give some feedback on this kit?
    Does the extra rotation cause much if any loss in precision over the 4th axis kit that just rotates?
    Does the sprutcam7 that comes with the Tormach allow you to tilt the 4th axis so you can actually make good use of this table when you're doing toolpathing?
    Another 4th axis general question:
    Obviously a lathe is the preferred tool for a cylindrical part, but can you make a near equivalent part slowly turning full revolutions with your 4th axis and using an end mill to remove material from the outside perimeter?
    Oct 2012
    42
    Quote Originally Posted by GJeff View Post
    Here's the tail stock for the tilting table
    30272 - Tailstock for Rotary Table (Medium)
    Tailstock for 6" Rotary Table, 6" Rotary Tilting Table, and 8" Rotary Tilting Table
    Price: $118.80
    Jan 2013
    263
    Right, but you're not going to get any use out of that when you've got something tilted up at 30-45 degrees i.e. actually using the tilting mechanism. You can probably only use the tailstock with 0 tilt but I'm not entirely sure.
  1. Z axis readout for tilting head mills
    By boxmaker in forum Benchtop Machines
    Last Post: 04-19-2012, 03:26 PM
  2. Tilting a part in mastercam
    By swannytheswan in forum Mastercam
    Last Post: 06-09-2011, 03:56 PM
  3. 5 axis and Mach - any experience?
    By LongRat in forum Mach Mill
    Last Post: 04-01-2009, 07:43 AM
  4. Left tilting or Right Tilting Table Saw Blade?
    By diarmaid in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 02-27-2009, 03:57 PM
  5. Tilting Spindle for X1?
    By heycorey in forum Benchtop Machines
    Last Post: 02-22-2009, 02:44 AM
