I hit the estop and turned off the HRT210 setting in the controler. Then I disconnected the HRT cables. Now the estop alarm wont clear out. I tried reconnecting the HRT but that did not work.
Any ideas on what has happened?
www.machmachine.com
Did you turn the machine off. Somewhere I have seen a warning that the rotaries must be connected or disconnected only when the main power is off.
I don't mean to insult anyone here, because I don't know your experience level, but just wanted to make sure that you knew that the E-Stop button has to be turned to release it!!!!!
In addition, make sure that the 4th axis setting actually says OFF.
Otherwise, I would just power down and restart.
Mike
Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
we we got it. Its always the dumbest things. The coolant pump cable was half way pulled out. Must have happened when we were disconnecting the HRT.
thanks anyways!
www.machmachine.com
I have had 4 service calls in my history.
Customer - I have an alarm, emergency stop
Me - have you tried all the estop buttons. Look around some machines have more than one
Customer- oh ya, I'm not stupid you know.
Me- is the machine overtraveled.
Customer-no its xxxx
Me-be there in an hour/day whatever
Me-emergency stop was pressed on chip conveyor/atc unit/remote pendant
Customer- oh, I didn't know there was one there
Me-minimum charge, sorry. Any other problems while I'm here.
Customer- embarrassed .
Happens more than you think.
Come on guys, fess up, come on!!!!!!
