588,340 active members*
5,315 visitors online*
Results 1 to 20 of 21
    May 2011
    22
    Fanuc o3p controller rs232
    hi everyone, sorry if this is a repeat question but i have just bought an Amada Aries 222 with a fanuc o3p controller. i would like to communicate with this machine via an rs232 cable and i was wondering if any of you would have a pin out diagram? i know it would be easier to buy a cable but ill be honest with you, i can get the bits for nothing at work and i thought it would be a good exercise to make one. any assistance would be greatly appreciated.
    thanks.
    2932
    This works for me:
    DB25M (CNC) <------------> DB9F (PC)
    1 <---------(SHIELD)--------- No Connection
    2 <--------------------------> 2
    3 <--------------------------> 3
    7 <--------------------------> 5
    4 & 5 jumped CNC end only
    6, 8, 20 jumped CNC end only
    May 2011
    22
    great!! thanks, i'll give it a try
    May 2011
    22
    ok, so i've made the lead, belled it out and it's all cool. i connected the machine and the computer. adjusted my DNC settings on the computer to 9600, even, 7, 2, iso, iso, Xon Xoff. but it doesn't seem to work properly. when i load into the machine it sends the first 2 lines of the program and throws an error. when i suck a program out of the machine it says the the file transfer is complete but when i open the file there is nothing in there. can anyone help me??
    Sep 2010
    1230
    Quote Originally Posted by kluppy View Post
    What error are you getting? If the cable has been made in accordance with the configuration described by Dave and machine parameters are set correctly, with the PC software setting set to match, then you should have no problems.
    Purchase a RS232 tester from an electronics store and place it inline with the cable connection. Try sending a program from the machine to the PC and look for activity on the pin 2 led from the machine. If there is activity and you get nothing at the PC, its probable that the PC software is incorrectly configured.
    Regards,
    Bill
    May 2011
    22
    thanks guys, yeah i need to figure out how to check the machine settings. any hints?
    Feb 2004
    52
    Kluppy
    You will find pinouts to suit Fanuc in the FAQ of my website - url below
    regrads
    Les Robbins
    EditComm - CNC communication software - Les Robbins CNC Services
    Mar 2005
    44
    Perhaps one of you guys can help me.
    I have an Amada Ariess 222 with Amadan 03P control, which I gather is actually a Fanuc in disguise.
    Its been in storage for a couple of years, and now refuses to accept any attempts at serial IO. The actual message that pops up when I try it is "Operation Error", which from the manual, is what you get when you try serial IO operations on a machine that is not fitted with the optional SIO ... except ours is fitted, and used to work, so I figure the machine has just suffered a bit of memory loss in storage ... everything else functions just fine though.
    So, any clues on how to get to the parameter page etc, I'm sure there will be a self explatory "SIO" or something parameter that just needs flicking from 0 to 1 ...
  1. RS232 link problem on CL200 with M64 Controller
    By rkucbel1 in forum Mori Seiki lathes
    Last Post: 12-14-2016, 08:29 PM
  2. Fanuc 0P-C controller RS232 Parameters
    By scottsr60 in forum Fanuc
    Last Post: 12-30-2014, 11:39 AM
  3. RS232 or CAN 2.0 Step Motor Controller Supplier from Shanghai
    By uirobot in forum News Announcements
    Last Post: 03-29-2010, 03:25 AM
  4. Download programs from controller thru RS232
    By CzechMarty in forum Daewoo/Doosan
    Last Post: 10-09-2009, 12:29 PM
  5. rs232 issues with a fanuc 6t controller
    By merrittr in forum Fanuc
    Last Post: 07-31-2008, 02:18 PM
