588,323 active members*
4,742 visitors online*
IndustryArena Forum > CNC Electronics > PIC Programing / Design > Want to get into pic programming.
Results 1 to 9 of 9
    1943
    I'm wanting to get into pic programming and was wondering if the linked development board would be an ok starting point.
    http://100mhz.com/pic-dspic-pic32-pi...ller-1074.html
    Dec 2003
    24220
    That board offers the larger Micro, I would suggest the 18 to 28 pin first.
    One good starting point is Nigel's PIC Tutorial Page
    If you are thinking in terms of C to program the 16F series is a good start, if you want to follow the assembly programming route then if you migrate to the 18F they are a bit easier to use.
    Another series of books is the Picmicro series by David Benson.
    Al.
    Albert E.
    Dec 2003
    24220
    One good starting point is Nigel's PIC Tutorial Page, the boards can be had here Prototyping Boards
    Al.
    Albert E.
    1695
    I would recommend that you get a MPLAB compatible in circuit debugger such as a pickit 3 or a clone for about $25. Then just get free dip PICS from Microchip and put them on a breadboard. All you need to hook up are the power and the 3 debug port pins. The crystal is not even needed on the newer chips.
    Dec 2003
    24220
    Further to the types, you are most likely to find more tutorials, projects and routines out there for the 16f series, such as the 16F628a, or that are easily converted to for learning on.
    These posses just about all of the popular functions built into them.
    Al.
    Albert E.
    Feb 2008
    217
    Try these:Product Search - microchipDIRECT
    I like these demo boards, kinda Arduino like. You have many good choices for compilers "C", "Proton"," PBasicPro" all have supporting forums (a really big help). All can use embedded assembly code or you can code in straight assembly.PICkit 2 Development Programmer/Debugger
    We're not in business to make parts, we're in business to make money, making parts is just how we do that.
    Apr 2022
    Re: Want to get into pic programming.
    Web development is such an career oriented field, in this field you will learn about developing websites, promotion, hosting, with the help of various web based languages like HTML,CSS,JAVASCRIPT and many other frontend and backend developments languages, if you want to learn then join
    web development courses in Delhi : http://www.admecindia.co.in/courses/...courses-delhi/
    web development course in Delhi : http://www.admecindia.co.in/course/b...master-course/
    Jan 2023
    The PIC microcontrollers is programmed by the embedded C language or assembly language by using appropriate dedicated software. We have used some aspects of it in our business. https://the2d3dfloorplancompany.com/
    We also have the following businesses.
    https://uwike.com/
    http://floorplanforrealestate.com/
    https://therealestaterenderingcompany.com/
    https://gntro.com/
    Aug 2023
    7
    I think I need a good hosting for this. I have nothing against an open-source hosting provider if you have a small or non-commercial project. In other cases, I would opt for something like my own private server, which would give me full control over the data. You can ask mac hosting folks what they can offer. I would rather join the opinion that reliability is key for hosting when it comes to business.
  1. Xilog 3 Parametric Programming Offline Programming
    By julioykaly in forum Commercial CNC Wood Routers
    Last Post: 04-27-2013, 09:22 PM
  2. Programming
    By mschmitz88 in forum Fanuc
    Last Post: 03-06-2012, 10:46 AM
  3. Programming
    Last Post: 02-18-2012, 02:51 AM
  4. PROGRAMMING HELP
    By forsale78 in forum Community Club House
    Last Post: 08-04-2010, 10:54 PM
  5. PLC PROGRAMMING
    By jp41558 in forum CNC Machine Related Electronics
    Last Post: 07-31-2008, 07:17 PM
