587,726 active members*
3,419 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > SX3... improper Mach3 pinout ?? no steppping
Page 1 of 4 123
Results 1 to 20 of 61
    Mar 2007
    215
    Hi all...
    I got my mill direct from Syil China...
    It seems the pinout doesn't match the Mach3 xml config file....
    After installing the latest version of Mach3... and loading the Syil America config file.... I came to the conclusion the pinouts are wrong for my mill... I also tried the Australian file (it's metric)....
    I got an "Installation Instruction Manual" with my mill... On page 8, it has the pinout, but it doesn't indicate the active state (hi or low)...
    Here is the pinout listed in the manual... (function, pin)
    x pulse 7
    x dir 17
    y pulse 6
    y dir 8
    z pulse 5
    z dir 16
    a pulse 4
    a dir 14
    spindle pulse 2
    spindle dir 1
    signal 1 3
    signal 2 9
    x home 12
    y home 13
    z home 10
    a home 15
    e-stop 11
    Now... When i configure it as to the manual.... The inputs work like they should... E-stop... X home... Y home...
    But... the steppers don't jog in Mach 3... the ouput pin lights in the diagnostic screen don't light in Mach 3 either... only the inputs show responce...
    So far.. I checked and tested... the stepper drivers are getting about 48 volts.. the red light comes on the drivers...
    The control board gets about 14 VAC from the small transformer beside it...
    I haven't checked to see if the parallele port is outputing 3.3 volts or more...
    My parallel port is enabled and the driver is loaded... its running on x378....
    So... other than checking that the parallel port is outputting a high enuf voltage (MSI K8N Neo4 MB / AMD Athlon64)... and not knowing what should be hi or low for the outputs... is there something else I have missed?
    Thanks,
    Michael
    Oct 2006
    975
    Hi Michael,
    There are some great troubleshooting videos on the Mach support website, and if you haven't viewed them already you might find the infromation helpful in finding the problem with your setup. I had to reverse the homing of one of my axis and a defective Y axis home switch and found the Mach support videos very helpful in my case. Do you have power to the axis drivers? Sounds like maybe the wire harness to the stepper drivers is not connected. I had a similar problem with no stepper power when I first tried my SX3 and found the wires connecting the drivers were not connected. Hope you are able to get it running soon.
    Regards,
    Regards,
    Wes
    Mar 2007
    215
    Hey~
    There is power to all four of there drivers... 48 Vdc, and the stepper motors are getting warm...
    I will check the port voltage (3.3v vs 5v)... however I'm not sure this is an issue with the SX3... The other thing I need to figure out is the active states (hi or low) of the various outputs...
    And what should the port setting be in the bios?... I've seen ppl say both ecp and spp..
    Thanks,
    Michael
    May 2006
    1469
    G'day Michael
    Fairly sure it won't be the voltage on the LPT. The controller board that Syil use buffers the logic signals.
    Are you sure you have the port address set correct? If your not sure about that go and look at the introduction video on the Mach site.
    Post your XML and I'll have a look.
    Greg
    EDIT: OK I did not read your original post properly. You have inputs working.
    Have you set the same port number for outputs?
    Mar 2007
    215
    Yes, everything is set to Port 1...
    I just changed the port type to EPP and will resistall Mach3 R2.60...
    Then I will use the Syil America XML file... and rewrite teh proper port numbers in ... without changing the active state setting (hi or low) ...
    After that... I dunno...
    Mar 2007
    215
    Ok, Reinstalled and re-setup the config file...
    Also tried Mach2
    Same thing.. I can sense the inputs in Mach3... but the motors dont turn...
    Something I jsut noticed after going thru the Mach3 setup video...
    Under device manager... my LPT1 resources... I have two I/O ranges...
    One is 0378 - 037F
    Second one is 0778 - 077B
    The Mach3 setup video only shows the first range...
    Could this be the problem??
    Mar 2007
    215
    Hi agian~~
    Here are a couple of pics of the LPT1 port screen and the Mach3 Diagnostic screen....
    The controller in the back of my mill says "ECTL" and "East Crystal Five Axis CNC Board Rev 1.3"....
    Is this the same board in the American SX3?? (or other countries..)
    Thanks,
    Michael
    May 2006
    1469
    Michael
    0378 is the number you want. When saved Mach will convert it to 0x378
    Post the XML you are getting inputs working with. Let's have a look at it.
    When you say the motors won't run, can you be more specific?
    What exactly are you doing? Do the DRO's run as if it is moving?
    Greg
    Mar 2007
    215
    The motors get warm... but they don't turn... they don't make a sound either..
    The DRO's do change as I press the buttons on the number pad... also change if I use the pop out (DRO) thingy (tab key)...
    Here is the custom XML file... its jsut a modified version of teh Syil American XML....
    Thanks,
    Michael
    Attached Files Attached Files
    May 2006
    1469
    Take these three things one at a time,
    On my X3 I don't have the "active low" ticked for motor outputs. I s'pose you have tried with them crossed.
    Have you done the driver test? What sort of result did you get?
    Set it to "Sherline Mode" then restart and see if they run.
    Greg
    Feb 2008
    13
    Same problem....
    OK. I have exactly the same problem, with a new X3CNC.
    The PC, runs my own stepper boards fine (smaller mill, that I am replacing with the X3). The 'two port addresses' thing in Windows, is a 'red herring', all 'ECC' printer ports will show the second addresses, but Mach, only wants, and uses the primary addresses.
    The PC, is happily able to see the X3 inputs (ESTOP etc), if configured using the paperwork (the .xml file from the US site, is simply 'wrong' for the new control board), but the steppers don't run. What pin were people trying for the charge pump signal?.
    Best Wishes
    Mar 2007
    215
    Hey~
    1) I did try them both ways... but I may have had the different pin configs then... I will try them agian on Monday, since the mill is at my office...
    2) The driver test showed a nearly straight line with minimal interference...
    3) I will try Sherline mode on Monday as well...
    I also ran the port finder and it came up with 378....
    Syil China said they would get back to me by email with the correct XML config file...
    Thanks,
    Michael
    May 2006
    1469
    Quote Originally Posted by krazatchu View Post
    Hey~
    Thanks,
    Michael
    OK I'll check back in on Monday.
    Greg
    Mar 2007
    215
    Oh,.. here is something intersting...
    While at my office, I checked my main work pc... It also had two ranges for the printer port resources in device manager... see post #7 above for the mill pc...
    It, as well as the mill control pc are both AMD systems...
    My work pc being a socket 939 dual core Athlon 64 on an Asus MB...
    And the mill is a socket 939 single core Athlon on a MSI MB...
    Now... I just checked my wifes pc, it's a core 2 duo Intel system on an Asus MB ...
    And it has only the single range of x378...
    My home pc, core 2 quad intel on an asus MB doesnt have a parallel port...
    But my TV pc is a P4 so I will check it asap (its in the bedroom and someone is taking a nap)...
    Hmm.. perhaps the extra range is confusing the output...
    Mar 2007
    215
    The P4 I have also has the two ranges x378 and x778 under the resource tab of the parallel port driver...
    35538
    It's not very likely the problem, especially since the inputs work. I'd also recommend setting Mach to 25Khz mode until you get it working.
    Check the voltage on one of the direction pins, and jog back and forth. It should change from 0V to 5V and back as you change directions.
    Mar 2007
    215
    Since I didnt get around to checking if it was either 3.3v or 5v... I will also check that on Monday.. along with checking for a direction pin...
    Here is the thing that I'm confused about tho...
    The bottom row of lights on Mach3 Diagnostic page don't change... they all just stay off... regardless of what axis I try to move... or what input I toggle...
    I can get 3 of the lights in the top row to change by toggling the x and y limit switches ... and by pressing the E stop button...
    So, Shouldn't some of these diagnostic lights on the Mach3 Screen be blinking when I change direction??
    May 2006
    1469
    .......The bottom row of lights on Mach3 Diagnostic page don't change... they all just stay off... regardless of what axis I try to move... or what input I toggle.........
    ........So, Shouldn't some of these diagnostic lights on the Mach3 Screen be blinking when I change direction??
    Michael there are no LEDs on the diagnostics page to indicate step and direction outputs. So don't expect to see them.
    If you are right about the different controller board then that may well be your stumbling block. Get your pin numbers right and it might be all go.
    Greg
    Sep 2006
    203
    ALL pc boards for ALL countries are made the same. This means the pinouts are the same for all machines. The only variable is the PC port.
    Even the 3.3v units work, but sometimes not as reliable without some ACPI changes.
    Before you can use the dianostic pages you need to establish communication between the PC and the mill. Doesn't sound like you are getting basic communication so the dianostics will do you no good.
    We have a few videos on the support tab of www.syilamerica.com that address port config. It is the same on all machines regardless of make. You may want to check the forums at www.machsupport.com.
    Direction, Commitment, Follow Through
    Mar 2007
    215
    Page number 8 of the "CNC SX3 INSTALLATION INSTRUCTION" book that came with the mill...
    This pin config and the American XML file don't match...
    Furthermore... When I tried the the American XML file... the E-stop button activated the digitize function...
    After changing the pin config in Mach3... I can now see the limit switches and the E-stop working correctly... from the diagnostics page....
    What doesn't work is the motors.. .they get warm.. .the drivers get 48 volts.. .but they dont move... even tho the DRO's do....
    So... In the American machines... do you use the same controller board?
    Mine is labeled "ETCL" and "East Crystal five axis cnc board rev 1.3"
Page 1 of 4 123
  1. Improper V-Ready Off Alarm???
    By Crashmaster in forum Fanuc
    Last Post: 09-09-2019, 04:55 AM
  2. #23-305-DS8A Pinout
    By Richie800 in forum Hobbycnc (Products)
    Last Post: 11-15-2007, 09:11 PM
  3. DB9 pinout cabling
    By miguisu in forum DNC Problems and Solutions
    Last Post: 05-23-2007, 12:21 PM
  4. Fanuc 11m error message. improper number of axis
    By kmcmillen571 in forum DNC Problems and Solutions
    Last Post: 04-02-2007, 01:14 AM
  5. svo13 y and u improper v_ready off
    By stanman in forum DNC Problems and Solutions
    Last Post: 11-15-2006, 03:11 PM
