587,245 active members*
3,115 visitors online*
Results 1 to 3 of 3
    Sep 2019
    4
    CNC Programmer Opportunity in Portland Area
    We have an opening for a CNC Programmer in the Portland Area.
    PM me if you are interested or looking for work.
    Aug 2019
    339
    Re: CNC Programmer Opportunity in Portland Area
    Job/tech description?
    2ax/3ax/4ax/5ax/6ax?
    Workstation's CAM/CAD tech involved?
    Industry?
    Without that info, you are basically targeting the "out of job/can't find a job" candidate(s)
    Sep 2019
    4
    Duties:
    Program new and challenging parts with ability to utilize or learn Autodesk Partmaker software
    Reprogram / troubleshoot existing parts and programs
    Interface with key customer account engineers to support part Design For Manufacture (DFM)
    Write clear set up sheets with detailed tooling plans
    Determine root cause and corrective actions to remove risk points and increase quality
    Supervise tool room and research the best tooling available for specific part requirements
    Help set up a best in class tool room
    Estimate machining time for new part quotes
    Estimate tooling costs for new part quotes
    Experience Required & Desired:
    Minimum of 2 years programming multi-axis Swiss & Mill/Turn machines for tight tolerance parts utilizing top technology software
    Experience & skill programming using Autodesk Partmaker preferred but not required
    Verifiable CNC Multi Axis set up, trouble-shooting & machining skills
    CNC Swiss Machining experience would be ideal but not required
    Speed and Feed knowledge on materials including difficult to machine materials such as titanium, Inconel, 17-4, 316 etc.
    2 years or more experience supporting and training other programmers/machinists
    Post editing experience would be excellent but not required
    Strong communication and interpersonal skills required
  1. Any Tormach Owners in Portland/Or area want to assist
    By idtat in forum Tormach Personal CNC Mill
    Last Post: 09-24-2017, 02:56 PM
  2. Replies: 51
    Last Post: 04-13-2017, 07:42 AM
  3. Toyo Tanso is looking to hire a CNC Programmer in Portland, US
    By Dovile in forum Employment Opportunity
    Last Post: 05-05-2015, 09:18 PM
  4. NEED: CNC HAAS HL-2 programmer in Portland Ore.
    By tpdusa in forum Employment Opportunity
    Last Post: 09-16-2008, 02:00 AM
  5. Portland Programmer
    By PortlandCNC in forum Employment Opportunity
    Last Post: 01-01-2008, 02:58 AM
