587,619 active members*
3,438 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Spindle problem NEED HELP
Results 1 to 15 of 15
    Jun 2007
    37
    Hello guys, having a problem with my spindle. I bought a C15 dual relay board to turn my router on/off and it was recommended to run a solid state relay also..so I wired everything up and and tried to see if the spindle would come on using M3 in mach3 and the thing wouldn't come on. So I went back and fourth trying other things in the software and still nothing..so now I'm thinking about the wiring I don't know if I have this hooked up right.i was wondering if you guys can help me out. I attached a diagram how it's hooked up..thanks guys
    15362
    Re: Spindle problem NEED HELP
    Quote Originally Posted by rick027 View Post
    Are you using 120v single phase
    Mactec54
    Jun 2007
    37
    Running 110v single phase.its just a 2hp porta cable router
    15362
    120v if you live in NA
    Why are you using the Relay Board the solid state Relay if 5v to 30v input can be switched direct from the Breakout Board
    Are you getting and output from the Breakout Board 0-5v check this with a meter this is what has to be working before you can check anything else
    Mactec54
    Jun 2007
    37
    Yes I'm getting 5v and I was only gonna use the relay board but in the instructions it said to also use a solid state relay so that's why I'm using a solid state with the relay board....
    15362
    Then that should be enough to switch the Solid State Relay by it's self, can you do a close up of the top of the SSR this will tell us the operating voltage and amperage most have an input of 4-32v Dc
    Yes the relay board could not switch the spindle by itself but may not be needed at all if you have the correct Solid State Relay which is a better way to do it
    Mactec54
    Dec 2013
    5716
    What is the part number on the SSR? A picture of it would be good. It looks like you are wired correctly per the diagram you show above.
    Will the router turn on if you apply 24V directly to the SSR input terminals?
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2007
    37
    Yes it turns and here's a pic of the ssr
    15362
    Looking at your relay you did not need the relay Board or the 24v Power supply that would work direct wired to your Breakout Board output 0-5v
    Mactec54
    Jun 2007
    37
    So mactec, you think I should try hooking it up jUst to the SSR and go from there
    15362
    If the Breakout Board has 0-5v when you use M3 and M5 then yes you can direct connect to the Breakout Board that's all the relay needs to turn it on and off
    Mactec54
    Jun 2007
    37
    Here's more pictures
    Dec 2013
    5716
    As near as I can tell your wiring looks OK.
    Looks like maybe you need to enable Output #2 and set to Port 0, and set the Relay Control screen (M3) to Output 2. Disclaimer: I'm not a Mach3 expert.
    Jim Dawson
    Sandy, Oregon, USA
  1. Spindle problem NEED HELP
    By rick027 in forum Spindles / VFD
    Last Post: 11-07-2019, 03:14 AM
  2. Spindle Problem or VFD Problem?
    By twbaisch in forum CNC Machine Related Electronics
    Last Post: 06-10-2019, 07:33 AM
  3. 3.7KW Spindle problem
    By Yasser47 in forum Spindles / VFD
    Last Post: 04-03-2017, 03:02 PM
  4. A Spindle Problem Found - A Spindle Problem Solved
    By oly2brf5 in forum Tormach Personal CNC Mill
    Last Post: 04-28-2013, 07:09 PM
  5. VM1 spindle problem
    By bimjackal in forum HURCO
    Last Post: 11-25-2008, 11:27 AM
