588,201 active members*
5,109 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Vertical/Horizontal Bandsaw purchase
    Sep 2004
    239
    Looking to purchase a V/H bandsaw, probably in the 7x12 capacity. Would like to poll anyone who cuts their own stock, what you are using and ask for your experience on what features to look for (geared versus belt drive, etc.) Which features are worth spending the money for?
    Jun 2007
    7
    Did you try the best Turkish Manufacturer's machine for Bandsaw UZAY MAKINA. www.uzaymak.com
    Mar 2006
    30
    http://hyd-mech.com look up the dm 10. We have a large one in our shop and it is like they say "rock solid".
    Jul 2005
    12177
    I have three different makes in my shop and the hyd-mech is the most convenient to use.
    This one has the rotating head for cutting angles so the length of material always stays straight along the feed rollers.
    It can cut past 45 degrees which is sometimes handy.
    It has a very solid vise.
    The controls are fairly user friendly; everything is grouped conveniently.
    My suggestion is to find a dealer with different makes set up and running so you can try the controls. Some makes you have to do two or three operations to start every cut, on the hyd-mech once things are set you just pull a trigger for repeat cuts.
  1. Looking to Purchase CNC Mill/Drill, which one?
    By mtuckf in forum Benchtop Machines
    Last Post: 04-12-2005, 02:39 AM
  2. want to purchase a CNC from anyone
    By corbyvhall in forum Benchtop Machines
    Last Post: 03-25-2005, 02:08 AM
  3. What to Purchase
    By Robin in forum MetalWork Discussion
    Last Post: 02-28-2005, 01:53 PM
  4. Bandsaw accuracy?
    By gtslabs in forum MetalWork Discussion
    Last Post: 12-30-2003, 04:26 AM
  5. Can you cut Al. with a wood bandsaw
    By CactusChip in forum MetalWork Discussion
    Last Post: 11-20-2003, 10:45 PM
