587,319 active members*
3,305 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Machine Face + OD, Flip part around, face to length and machine the rest.
Results 1 to 11 of 11
    Sep 2010
    135
    I have been wondering how do you guys program and set-up this flip part around thing using the same work shift.
    I found some difficulties, I figure that if the part projection is the same on both sides it will work with the Z0.0 but when one side sticks out more than the other it won’t work.
    Any inputs please
    Feb 2008
    586
    You could try and program the whole thing from the "stop" out, and all of your Z's (I'm assuming a lathe) will be positive, and your Z zero is the stop face.
    Sep 2010
    135
    Quote Originally Posted by beege View Post
    hum!!! Yes a lathe, fanuc...
    That could work yes indeed but I'm afraid that system would create some difficulties to some of the operators.
    Any ideas on how to using a imaginary work shift on the lathe?
    2932
    You could also use 2 sets of geometry offsets: T0101 for the first side, T0121 for the second side. Of course that's assuming you have geometry offsets.
    Dec 2004
    150
    Hi, We turn both ends of component frequently. Why not have 2 offsets ie G54=1st end, G55= 2nd end.
    Keith.
    Sep 2010
    135
    Both are good ideas,
    Using G54 and G55 is not an option; my machines [Nakamura-tome fanuc] do not have that option, only one work shift…
    for what I know.
    I was wondering that I could create some sort of an imaginary work shift, like a macro location.
    Any ideas?
    2932
    I believe you could use G10 to set the work shift at the start of each half of the program - if you have the option. You don't say what model Fanuc you are running.
    Sep 2010
    135
    I do have 18-t, 21-tb, o-t, m5
    I have other machines with live tooling that allow me to use G54 etc...
    How would the G10 work?
    2932
    As I look through the 21T-B manual, I can't find a command for setting the Work Shift. Could be I was mistaken about that.
    Let's try the User Macro route. Just for the heck of it, try this command in MDI:
    #2601=9.9999
    See if the Work Shift value changes to 9.9999, or if you get an alarm.
    Sep 2010
    135
    Quote Originally Posted by dcoupar View Post
    #2601=9.9999
    Dcoupar, looks like I got it to work, with your help of course..
    I went to this Fanuc 18-T
    MDI / #2601=9.999 / start and the Z value on the work shift changed to 9.9990
    So I can use this User Macro route to flip parts around and etc..
    Nice going Dcoupar
    Have a good weekend
    2932
    Glad it worked out. Enjoy the weekend.
  1. how to flip a part
    By cob in forum Mastercam
    Last Post: 12-02-2008, 04:48 PM
  2. Newb, how to flip part
    By idkman in forum MetalWork Discussion
    Last Post: 10-21-2008, 03:12 AM
  3. Looking for face / drill / tap machine
    By seco in forum MetalWork Discussion
    Last Post: 03-21-2007, 08:22 PM
  4. angular contact bearings face to face??
    By powerfade in forum DIY CNC Router Table Machines
    Last Post: 06-19-2005, 05:01 AM
