587,201 active members*
3,071 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Small single-point internal threading
    Sep 2010
    I'm interested in tooling up to do single-point thread cutting on my Taig mill, and thinking that an indexable insert system makes the most sense, but am a little bewildered by the variety available.
    One of the projects that I have in mind is to make a new Tr12x1.5 lead nut for my garage-sale chinese 3-in-1 lathe.
    Are there any insert systems that can thread a bore as small as 10mm?
    Nov 2005
    28
    I would go solid myself
    Sep 2010
    Quote Originally Posted by SumDumPhuckr View Post
    I've looked around a little, and can't find a solid trapezoidal threading bar. Would you suspect that I'd have to hand-grind one?
    Mar 2005
    1136
    smallest I've done was a 3/16 two start 20 tpi, just under 5mm. That's a coarse small thread for single pointing! It worked but was a nail biter. Easiest way to tool for it is make it from drill rod and heat treat. You can turn the tiny 60 part as a profile then file/mill away what you don't need and file relief. If you've not made a cutting tool before, its much easier than it sounds
  1. Single point threading (lathe) with EMC
    By chafik in forum LinuxCNC (formerly EMC2)
    Last Post: 06-08-2008, 12:04 AM
  2. Replies: 10
    Last Post: 02-07-2008, 08:28 PM
  3. Single point threading
    By DragnsBane in forum MetalWork Discussion
    Last Post: 10-06-2007, 05:25 AM
  4. Single Point Threading Inserts
    By John3 in forum Polls
    Last Post: 08-06-2007, 03:45 PM
  5. Single point threading
    By kdoney in forum Mach Mill
    Last Post: 02-09-2006, 06:13 AM
