603,924 active members*
3,290 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Polls > Single Point Threading Inserts
View Poll Results: Which Single Point Theading Insert(s)?
Voters
53. You may not vote on this poll
  • I use "Top Notch" style.
    30 56.60%
  • I use "On-Edge" style.
    8 15.09%
  • I use "Lay-Down" style.
    16 30.19%
  • I use tooling other than above for single point threading.
    3 5.66%
  • I avoid single point threading in favor of other methods.
    3 5.66%
Multiple Choice Poll.
    Mar 2007
    207
    'Looking for advice and opinions about which is the "best" style of single point threading inserts. Things like the following all probably vary between the styles available.
    1. Variety and quantity of sizes / pitches threads cut
    2. Cost / Availability / points per insert.
    3. Variety of internal and external holder.
    4. Strength and life of the point.
    -John
    Mar 2007
    4
    when it comes to threading ,I prefer to use use top notch inserts ,they are simple to use,very rigid and it provides good finish, and with the right feeds and speeds you can go for many pieces without insert changes.
    one of the things I like obout top notch threading holders is that you reduce inventory by not having to buy grooving tools were you can use the same holder for threading and grooving.
    you have olso multiple sizes for different pitches.
    I am sure every machinist have their own preferences.I tried to get what ever gets the job done and will not sacrifice quality over price ;for me Kennametal works and they deliver they have different tool sizes wheter you chase O.D or I.D threads the importance of a solid set up is allways number one priority.
  1. Thread milling with single or multiple inserts?
    By magneto259 in forum MetalWork Discussion
    Last Post: 04-12-2007, 04:39 PM
  2. Single point vs. multipoint threadmilling
    By RoboElvis in forum MetalWork Discussion
    Last Post: 03-27-2007, 08:11 PM
  3. Single point gear cutting
    By jguillen08 in forum Mechanical Calculations/Engineering Design
    Last Post: 06-07-2006, 04:07 AM
  4. Single point threading
    By kdoney in forum Mach Mill
    Last Post: 02-09-2006, 06:13 AM
  5. Thread milling single point tool
    By Ikon in forum MetalWork Discussion
    Last Post: 08-22-2005, 11:15 PM
