603,796 active members*
2,619 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Hitachi Seiki 4NE11 with blank 9" CRT
Results 1 to 6 of 6
    Oct 2007
    179
    Hi I have an Hitachi Seiki 4NE11 cnc lathe with Fanuc 6TB.
    It's a new project and i'm trying to get it up and running after a year in storage.
    All seems well but the 9" green crt is not lighting up after I switch on.
    The X Z axis are working fine and will jog around no problem and the hydraulics hums away like it's never been switched off but without the screen I can't home or check any diagnostics.
    It has a Micon 8 controller on the back cabinet which seems to be working fine. All the alarm codes are ok apart from 28A which has a 1 in each address space refering to 100v, 24v and 12v power supply issues (the manual is in in Jinglish so not very clear!)...might be because it isn't homed yet?
    All the power supplies seem fine in the drive cabinet...no error led's etc.
    Thanks for any help guys.
    John
    Feb 2009
    6028
    I believe there is a power supply board mounted to the left of the CRT, is that one working?
    Oct 2007
    179
    Hi will check that today. The manual says check for 12v between the fuse and 0v but not sure which pin on the edge connector is 0v. The crt has an orange light(tube heater?) on the back so presume power is getting to it.
    Thanks John
    Oct 2007
    179
    Just to update. Swapped the old crt for a new unit found on Ebay. Screen works fine now.
    Feb 2011
    640
    just a note-
    a LOT of 9" monitor failures can be fixed with just a soldering iron... the board on the side of the control has a kinda circular pin pattern where the flyback mounts- seen MANY with little round cracks around those pins...just the weight of the transformer/vibration will cause cracking in the solder. probably at least 2/3 of our 9" monitor problems could be repaired by simply remelting those pins to reconnect them.
    bad solder joints often pop up with bright or dark screen, sometimes thumping the panel will make it flicker too...resolder those pins, it usually works fine.
    Oct 2007
    179
    Thanks will check the old screen unit might be able to repair it and keep as a spare
    John
  1. fANUC 6T "HITACHI SEIKI"
    By yumuri in forum Fanuc
    Last Post: 01-12-2010, 11:22 PM
  2. fanuc 6T "HITACHI SEIKI"
    Last Post: 01-12-2010, 07:26 PM
  3. fanuc 6T "HITACHI SEIKI"
    Last Post: 10-31-2009, 04:38 PM
  4. NEED cast iron blank 7"x1.5"
    By captainlee in forum MetalWork Discussion
    Last Post: 07-03-2008, 07:54 PM
