587,704 active members*
3,669 visitors online*
    Mar 2012
    Cutting HDPE Question....
    Was curious, I have never milled HDPE before and wanted to run this by someone before I started...
    I have a Probotix v90 with a Bosch Colt, I am cutting a 1/2" think piece of HDPE with a 1/8" 2 flute solid carbide bit.
    So, the questions are:
    Do I need to use higher RPMs than what I would use with wood or lower?
    Should I travel faster or slower, or just keep it the same in travel speed?
    I cut many different woods before, Birch Ply, Koa, Paduk, Maple, Pine, Wenge, and others, I have just never worked with HDPE before...
    Thanks for the help in advance.
    35538
    Depends on what you used for wood, but generally lower.
    Again, depends on what you were using.
    A single O flute is a much better choice for plastics than a 2 flute.
    Mar 2012
    I guess numbers would have helped....
    I typically run the bosch colt around 28,000 rpms to 30,2000rpms for my wood cutting with a travel speed of 15-20 inches per minute.
    For harder woods, I slow the cutter down to around 22,000 rpms. and my travel to 8 - 10 inches per minute.
    Most of the stuff I have been cutting with has been with a 1/16" 2 flute (for birch ply) or a 1/4" or 1/8" 2 flute (for solid woods to include my hard woods)
    With hard woods I have always gone lower and slower for RPMs and travel, but with HDPE, I see that it can melt easily if your not careful. Plus I would imagine it will gum up, fill the flutes and break the bit if it got too hot. That is why I am asking. I have the CAM file set to shave 1mm at a time in depth but it shouldn't sit too long in one place (except for the plunges).
    Typically with wood, I take about 1/8 off at a time.
    35538
    With a 1/4" bit, cutting hardwoods, you'd get far greater tool life at 15,000 rpm and 100ipm. For HDPE, I'd try about 20,000rpm and 125ipm.
  1. Cutting HDPE and Acetal sheets with a CO2 laser ?
    By nio101 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-12-2012, 06:43 AM
  2. Laser cutting HDPE??
    By Dubliner in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-24-2010, 10:13 AM
  3. HDPE cutting problem
    By leaveme in forum DIY CNC Router Table Machines
    Last Post: 11-07-2010, 03:29 PM
  4. DIY router parts: HDPE vs cutting board
    Last Post: 09-14-2010, 08:38 AM
  5. Anyone use HDPE decking lumber instead of cutting boards?
    By dbprojects in forum Commercial CNC Wood Routers
    Last Post: 05-12-2007, 03:29 PM
