587,744 active members*
3,631 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Help With New Stepper Drive Setup
Results 1 to 9 of 9
    Sep 2012
    106
    Hi guys. Been browsing around for a while trying to find some info ive been looking for. Heres my setup:
    DTLLC 10A Unipolar Stepper Drive, running 12V bus voltage
    3- 63KG-CM unipolar steppers, 8 wire, 6.6V, 3A/Phase
    Mach 3
    Fixed Gantry 3 axis mill, Live Z axis, counterweighted
    Steel Frame, 1" Round Linear Slides
    1.5" Ballscrews
    Timing Belt Reduction Gears
    24x24 working size
    Finally got some answers I was looking for last night, about high bus voltage. Read that bus voltage should be 10-24x rated stepper voltage. So that puts me at about 70V minimum. I have some 60V supplies lying around, so ill probably start with them. I dont have a chopper drive board, so I need to run resistors for current limiting correct? Im sure I can find a calculator online. My DTLLC board has a huge sink and fans on the driver chips, and has ran 8A 12V for days and days before.
    My original issue was with stepper speed, but running them at 12V no doubt they werent running at their full (or even close to) potential. The DTLLC chips are rated at 100V 25A.
    Should I buy a set of chopper drivers? Keep the DTLLC board and run resistors? Any specific voltage I should run?
    Main purpose of this machine is some aluminum milling with coolant, MDF cutting, and some engraving work in all sorts of materials.
    Thanks a ton in advance. I can take some pictures if needed.
    Nov 2014
    34
    Re: Help With New Stepper Drive Setup
    try gecko drives , you save lot of time needed to setup.
    Sep 2012
    106
    something like this? Is that power supply going to be enough amperage?
    Gecko G540 Controller Current Version with 48V 7 3A Power Supply | eBay
    Nov 2014
    34
    exactly
    Sep 2012
    106
    Ill have to give it a try. I always hated having to cool limiting resistors.
    Nov 2009
    4415
    The G540 is a great board. It has a maximum of 48vdc and a 3.5A per stepper. The Leadshine MX3660 allows a higher input voltage of around 52vdc but with 5A per stepper.
    Not sure what you meant about cooling the resistors. However the G540 will require resistors too.
    A lazy man does it twice.
    May 2005
    1397
    The resistors on the G540 are /sense/ resistors, not limit resistors. They shouldn't need cooling.
    On the other hand, you also don't really need 60 or 70 volts. That's just crazy talk! LOL... Even really massive, fast moving, CNC machines shouldn't need more than 48 volts.
    In any case, please take care to be very safe with the wiring... 60 volts will get past your skin resistance quite nicely, even without sweat, and if you manage to make a circuit across your heart, it will kill you dead right now.
    Some ideas for power supplies here:
    techref.massmind.org/techref/io/stepper/power.htm
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Sep 2012
    106
    James, on the cooling resistors, I was referring to the current control ones I had to use with my DTLLC board. Even running 50 Watt ones they would cook!
    Sep 2012
    106
    Thanks for the info guys. Im trying to get the machine up and running on a tight budget, I spent all my funds on ball screws and rails. I bought a cheap 3 axis chopper driver set off ebay, and a 0-36V 0-15A power supply so I can tune for best voltage. Hopefully this gets me up and running for good. I cant believe ive been running two other machines on 12V with resistors for so long. No wonder my feed speeds had to be so low!!
  1. Replies: 1
    Last Post: 08-04-2013, 01:53 PM
  2. Spindel drive VFD. Setup help please
    By johnn1 in forum SmoothStepper Motion Control
    Last Post: 02-24-2012, 11:41 PM
  3. Questions on drive setup
    By elogicca in forum Linear and Rotary Motion
    Last Post: 05-15-2007, 06:33 PM
  4. Need help with servo/drive setup
    By CreativeOffroad in forum DNC Problems and Solutions
    Last Post: 02-21-2007, 07:34 AM
  5. difference between a stepper indexer and a stepper drive
    By pcroxford in forum Stepper Motors / Drives
    Last Post: 11-02-2005, 02:35 PM
