603,870 active members*
2,726 visitors online*
    Jan 2005
    183
    Questions on drive setup
    I was thinking of doing a 4x8 linear rail & rp, how hard would it be to sync 2 servo's on dual r&p ? or would steppers be a better choice? belt linking the dual r&p won't be an option... would 495oz steppers be ok if not servo's?
    Dec 2003
    24260
    To do it with servo's you would really need to use a closed loop system like Galil or Acroloop, they have specialized instructions for slaving one servo off another, MG Systems & Koike-Aaronson used Acroloop using this method for their large industrial Plasma gantry's at one time.
    Al.
    Albert E.
  1. Need help with servo/drive setup
    By CreativeOffroad in forum DNC Problems and Solutions
    Last Post: 02-21-2007, 07:34 AM
  2. servo setup questions for mach 3
    By planeflier in forum Mach Mill
    Last Post: 06-06-2006, 02:08 AM
  3. More Mach3 Setup Questions
    By bill south in forum Mach Mill
    Last Post: 05-08-2006, 04:10 PM
  4. Setup Questions
    By WarrenW in forum SheetCam
    Last Post: 01-31-2006, 10:01 AM
  5. Hardware Setup Questions for New CNC Machine
    By tpicker1 in forum Benchtop Machines
    Last Post: 05-04-2004, 03:43 PM
