587,997 active members*
1,832 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Prolight 3000 lathe 5c collet closer
    Jan 2013
    4
    Anyone out there have or have seen the 5c collet closer for these machines? I'm looking to either purchase one or copy someones/
    Thanks,
    Lloyd
    May 2009
    141
    Re: Prolight 3000 lathe 5c collet closer
    Hello, I have the same lathe, but no collet closer. I have however seen pictures of one and it's nothing but a long pipe with a hand wheel on one end and threads on the other for a 5C collet. The pipe is passes through the spindle and at the end is the hand wheel to tighten the collet which presses up against the spindle when tightened. The only thing you have to figure out is the total length so the collets pull into the spindle correctly.
    Making one has been on my list of things to do, but I just haven't found the time.
    Good luck!
    Dale P.
    Apr 2011
    131
    Quote Originally Posted by ibuildstuff4u View Post
    Necrobump. Dale. Did you ever make one of these? I just purchased a 3000 and am also missing the collet closer.
    Mar 2007
    304
    Hi LloydCam,
    - I have two (2) Dyna Myte 3000 lathes.
    - One has a factory built pneumatic 5C collet opener/closer on it.
    - I plan on taking it off and reverse engineering it, and when I do - I will make a full set of drawings and post. (But trust me - I have a zillion projects in front of it - it won't be any time soon).
    - My end game plan is to make the 5C collet Opener/Closer activated by relays, and operate that via Mach3. Basically this will give me a poor man's barfeeder. I'd like to additionally hook in a tachometer and make it a smart system, but will probably have to use an Arduino (or something similar) to handle the additional logic and I/O.
    Joe
    www.CNC-Joe.com
    CNC Is Not Just My Passion.. It's My Addiction !!!!
  1. Just bought a Prolight 3000 lathe
    By boatlover in forum Mini Lathe
    Last Post: 12-19-2021, 09:01 PM
  2. Lathe Collet Closer
    By menzzer37 in forum Tormach Slant Lathe
    Last Post: 05-13-2021, 07:57 PM
  3. Prolight 3000 turning center (lathe)
    By closetgenious in forum Maintenance DIY Discussion
    Last Post: 02-07-2014, 06:05 PM
  4. CNC proLIGHT 3000 lathe
    By SRTSS in forum Machines running Mach Software
    Last Post: 03-17-2013, 04:40 AM
  5. mini lathe lever collet closer?
    By InspirationTool in forum Mini Lathe
    Last Post: 09-03-2010, 09:39 PM
