587,619 active members*
3,506 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Been RIPPED OFF !! Beware
Results 1 to 9 of 9
    Feb 2015
    11
    Angry Been RIPPED OFF !! Beware
    Hey guys had a bad experience with JEFFCNC was adamant about what we were machining and even asked if he wanted our .vnc file. He did not want to see it, ask me to pay and then send sample print out of basic program so he could see machine format expected. He told me to order 4th axis simultaneous post from his website so I did. We got it and it did not put out any A rotation, so after going back and forth a few times he then asked for our .vnc. He then replied we could not use 5 axis programming with 5th locked at zero and we need a 5th axis post to do that at an additional $899 above the $574 we already paid him. He said he had already spent time so he did not know what else he could do for me!!! Never accepted any ownership in the problem. Never showed any intention to rectify without being paid more money......I'm pretty sure that would be called extortion!
    I washed my hands of him and had AJESMS work on a post for us. He has been a joy to work with and we have a wonderful working post and are cutting parts!! His prices are reasonable and his knowledge is paramount.
    I'm sure there are guys who have got post from JEFFCNC but my experience was horrid and has left me with $574 gone from my pocket! Think about it before you jump make sure your post writer really understands what you want and expect to get, insist on sending that part file so they know. If they are not concerned and only seem interested in you sending the money walk away....no actually RUN!
    Jun 2015
    25
    Re: Been RIPPED OFF !! Beware
    You should really do a little research before you spend $574 next time. Do yourself a favor next time and pick up a phone and ask questions like that to licensed professionals that can point you in the right direction and tell you right away that you would need a 5-axis post in order to output the required programming. Then once you have all the information you need you can go to a guy like JEFFCNC or JOEVNCBLOBXXXPOSTMAKER and get them to create you post with every possible piece of information about your machine/modules as possible.
    JEFFCNC had no idea of what you were working with and that was your responsibility to tell him before you bought a product. Post making is NOT easy and there's a reason so few people actually do it.
    A little research goes a long way and saves you a ton of cash.
    Feb 2015
    11
    I guess you missed the part where I ask him if he wanted our .vnc file and he said no. But then when there was a problem he wanted to see it. I made the assumption that when you ask to do simultaneous 4th axis machine of 3d objects, and that we wanted continuous a motion on the fly that the post writer would know that we are not wanting the y axis to stay in center-line and milling a slot!
    Jun 2015
    25
    Yeah, you just assumed. Never assume. Always ask.
    Now you know not to waste money based on assumptions.
    Glad you got your problem solved though.
    May 2012
    85
    I HAVE DONE BUSINESS WITH BOTH AJEMS IS REAL GOOD BUT IF HE CAN NOT SOLVE PROBLEM HE WILL TELL BE QUIET HE HAS OTHER THINGS GOING!!!
    JEFF WILL NOT EVER SEND TEXT FILE WITH POST FILE SO YOU ARE PAYING FOR ALL AND GETTING HALF WHAT YOU APT FOR!!
    WHEN YOU BUY A POST IT IS ALWAYS .PST AND .TXT FILES THIS IS A TRUE PURCAHSE!
    STILL WAINTING FOR MY POST TO BE FINISHED QUIET!!
    Jan 2022
    8
    Thanks for let me know that, I was going to have them edit a post for me.
    Jan 2022
    8
    So when it comes down to it who do you guy suggest to use? I would like this
    I would every G41 call to have the D word on every line, like: G41 D1 <--------every time the G41 is called, the D word in on the line.
    N3( FORMAT: GC #1A - G91G28Z0 - GOOD -D- WORD- 2)
    N4( 2/1/2024 AT 4:50 PM)
    N5( OUTPUT IN ABSOLUTE INCHES)
    N6( PARTS PROGRAMMED: 1)
    N7( FIRST TOOL NOT IN SPINDLE)
    N2( (
    ( ALUM
    ( X8.700
    ( Y8.700
    ( 2.500 THICK
    ( X0/Y0 CENTER OF PART
    ( -Z0- IS TOP OF PART AFTER SHELL-MILL CLEANS UP 100%
    ( DEEPEST CUT AROUND OD IS Z-1.800
    ( HOLD IN VISE WITH 1.800 MIN CLEARANCE AROUND O.D.
    N3( FORMAT: GC #1 GOOD TOOL LIST-GOOD G53 G41-[PMW] )
    N4( 2/1/2024 AT 5:07 PM )
    N5( OUTPUT IN ABSOLUTE INCHES )
    N6( PARTS PROGRAMMED: 1 )
    N7( FIRST TOOL NOT IN SPINDLE )
    N8( TOOL 1: .5 SPOT DRILL / .500 DIA NC SPOT DRILL )
    N9( TOOL 2: .201 DRILL / #7 jobber drill )
    N10( TOOL 3: .201 TAP 1/4-20 TAP / IN COMPRESSION TAP HOLDER )
    N11( TOOL 10: 2. SHELL ENDMILL / SHELL-MILL 2.00 DIA )
    N12G20
    N13T1M6
    N8G20
    N9T1M6 I want to look like this N9T1M6( / .500 DIA NC SPOT DRILL) --- tool call and comment line on same line.
    N10( OPERATION 1: HOLES)
    N11( --------MAIN)
    N12( TOOL 1: .5 SPOT DRILL)
    N13( / .500 DIA NC SPOT DRILL)
    N14( CS#1 - XY PLANE)
    N15G90G94G40G80G17
    N16S200M3
    N17G90G0X-5.Y5.G54
    N18G43Z1.H1M8
    N19Z.1
    N20G81G99X-5.Y5.Z-.14R0.1F10.
    N21G0G80Z.1
    N22M9
    N23M5
    N24G91G28Z0.
    N25M1
    N26T2M6 N26T2M6 ( / #7 drill) ---------------- tool call and comment line on same line.
    N27( OPERATION 2: HOLES)
    N28( --------MAIN)
    N29( TOOL 2: .201 DRILL)
    N31( CS#1 - XY PLANE)
    N32G90G94G40G80G17
    N33S200M3
    N34G90G0X-5.Y5.G54
    N35G43Z1.H2M8
    N36Z.1
    N37G83G99X-5.Y5.Z-1.5R0.1Q.09F10.
    N38G0G80Z.1
    N39M9
    N40M5
    N41G91G28Z0.
    N42M1
    N43T3M6
    N44( OPERATION 3: HOLES)
    N45( --------MAIN)
    N46( TOOL 3: .201 TAP)
    N47( 1/4-20 TAP)
    N48( CS#1 - XY PLANE)
    N49G90G94G40G80G17
    N50S200M3
    N51G90G0X-5.Y5.G54
    N52G43Z1.H3M8
    N53Z.4
    N54G84G99X-5.Y5.Z-1.5R0.4F10.
    N55G0G80Z.4
    N56M9
    N57M5
    N58G91G28Z0.
    N59G91G28Y0.
    N60M30
    Jan 2022
    8
    Who is AJESMS? His Contact info please.
    [email protected]
    Feb 2011
    10
    Just communication problem, more info here:
    https://jeffcnc.weebly.com/gibbscam-info1.html
  1. BobCAD Costs? HELP!!! RIPPED OFF???
    By paulgt3 in forum BobCad-Cam
    Last Post: 06-27-2012, 09:20 PM
  2. Think I got ripped on a Citizen F-25
    By Rob_smith in forum CNC Swiss Screw Machines
    Last Post: 09-21-2010, 02:18 AM
  3. Argh! Was I ripped off? Please Help Me!
    By Sporqster in forum Benchtop Machines
    Last Post: 07-10-2010, 05:07 AM
