587,426 active members*
4,588 visitors online*
Results 1 to 5 of 5
    Jul 2016
    25
    Holding Rectangular Aluminum Tubing
    Hello,
    I am working on a chassis piece for a robot. My stock is a 3 foot length of 2"x4"x.125" rectangular aluminum tubing. I need to mill various holes and pockets on all four sides of the tubing. I have designed the piece in Fusion 360 and intend to draw the toolpaths using Fusion as well. I will be using a Tormach 770 mill.
    How should I hold/fixture the tubing on the mill? Is there a way that I can make a jig so that the tubing doesn't have to be resquared each time it is rotated? Any ideas?
    Sep 2006
    6463
    Re: Holding Rectangular Aluminum Tubing
    2 vices spaced apart in line?
    Jul 2016
    25
    Quote Originally Posted by handlewanker View Post
    At this point, I only own 1 vice and was hoping to find a solution that doesn't require an additional one.
    Jun 2004
    6618
    1 vise and a machinists jack screw.
    https://www.amazon.com/s/?ie=UTF8&ke...l_1ph6kkrfe3_e
    Or just support it with 123 blocks and parallels. Shave down a piece of lumber.
    Lee
    Dec 2013
    5716
    Bolt a straightedge down to your table. This could be anything that you have laying around, steel, aluminum, or even MDF or plywood. Take a cut on it to square it to the table. If you put a generous chamfer on the front edge prior to bolting it down, then there is no danger of the endmill going into the table when taking a squaring cut. This gives you a backstop to position the tube against. Then bolt down an end stop, this positions the tube in the X axis. Then clamp the tube down as needed.
    Jim Dawson
    Sandy, Oregon, USA
  1. Replies: 2
    Last Post: 11-07-2015, 06:28 AM
  2. Rectangular Tubing Sources?
    By zcases in forum MetalWork Discussion
    Last Post: 01-27-2011, 03:10 PM
  3. Tube Bending Machine Capable of 2"x4" Rectangular Tubing
    By morribi in forum Bending, Forging, Extrusion...
    Last Post: 06-27-2010, 04:47 PM
  4. Steel rectangular/square tubing wall thickness
    By pstockley in forum MetalWork Discussion
    Last Post: 01-27-2006, 08:56 PM
  5. diy vmc from rectangular steel tubing ?
    By andy55 in forum Vertical Mill, Lathe Project Log
    Last Post: 01-02-2006, 10:59 PM
