587,434 active members*
3,077 visitors online*
IndustryArena Forum > MetalWorking > Bending, Forging, Extrusion... > Tube Bending Machine Capable of 2"x4" Rectangular Tubing
Results 1 to 10 of 10
    Jan 2007
    8
    I am wanting to design a tube bender capable of bending 2"X4" rectangular tubing.Do anyone knows how to calculate how much force that would be required to bend tubing this size?I was thinking maybe building a cnc mandrel tube bender using a 40 hp electric motor.Input would be greatly appreciated.
    Jun 2007
    12
    Material and wall? Easy way or hard way? Bend radius?
    Jan 2007
    8
    Hey Mikek10
    Quote Originally Posted by mikek10 View Post
    Mikek10,
    Thank you for responding. The material is 2"X4" mild steel and the minimum wall thickness is .25". I will be bending the easy way and the bend radius will be 10 inches up to 13 inches.
    Jun 2007
    12
    The figures I am getting are:
    Bend Force = 0.8 Newton Metres
    Pressure Die Force = 285.7 Nm
    Mandrel Force = 114.3 Nm
    Clamp Force = 114.3 Nm
    Wiper Die Force 85.7 Nm
    I would work on a safety factor of at least 3, probably more on the bend force which looks surprisingly low to be honest
    Jun 2007
    12
    I must have been having an off day when I worked out the figures above - did them in mm rather than inches!
    Real figures are:
    Bend Force = 9365 Newton Metres
    Pressure Die Force = 184335 Nm
    Mandrel Force = 36867 Nm
    Clamp Force = 36867 Nm
    Wiper Die Force 55301 Nm
    Jan 2007
    4
    Mike,
    What equations are you using for those calculations? I am interested in being able to calculate various round tubing (steel) sizes and wall thicknesses. Any help would be greatly appreciated!
    [email protected]
    Jun 2007
    12
    I work for a company that manufactures tube bending machines.
    We have written a program to do these calculations for inhouse use and for doing xyz>ybc conversion etc. Though we have sold copies on occasion
    Oct 2006
    15
    You can't apply force with the wiper die. The mandrel force = clamp force doesn't make any sense either.
    Jun 2007
    12
    Its the force against the wiper
    mandrel force always equals clamp force
    Jun 2010
    I'm not able to help you with machine design but our company currently has machinery and tooling capable of bending this to an 11" clr or 13" clr if you are interested in purchasing the parts rather than building the machine. Thanks.
  1. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
  2. BattleAxe "aka" Ball and Chain "aka" the wife.
    By ZipSnipe in forum Community Club House
    Last Post: 05-18-2008, 03:53 PM
  3. Questions on building small (18" x 24" x 3") machine
    By bikedude880 in forum DIY CNC Router Table Machines
    Last Post: 08-01-2006, 03:04 AM
  4. Vertical system "jerks" and "bangs"??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 06-12-2006, 03:09 PM
