587,880 active members*
3,917 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Can I reduce acceleration of axis lower than what mach3 allows?
Results 1 to 17 of 17
    Nov 2017
    591
    Ran into an issue with my mill turn. My swap axis switches spindle control between the mill turn and the main vertical spindle. Because of this, both are following the same spindle pulley settings which i need set to 24000 rpm max for the main spindle. This means my step/dir controlled mill turn spindle needs to have it's max velocity set to 24k rpm for the units to work correctly with the spindle pulley settings even though I don't run it above 3k rpm. With a minimum acceleration setting (about 4 seconds to max rpm) this takes my mill turn spindle from 0-3k in a half a second, which is too much and
    Usually faults the servo drive, especially on the deceleration.
    How can I get around this and set the acceleration lower than the minimum it's allowing? Not sure why there's a limit there in the first place. Should be able to accelerate as slow as you want.
    Dec 2013
    5716
    Re: Can I reduce acceleration of axis lower than what mach3 allows?
    Can you override the accel setting in the aux servo drive?
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2017
    591
    Not with step/direction control. In speed mode you can, but since this is a spindle/4th axis, I need to use step/dir for both
    Dec 2013
    5716
    I dunno, change the accel to 8 seconds maybe? Not sure how to solve this one.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2017
    591
    Yeah that's the issue, mach3 won't allow me to set it any slower. If entering a lower value, it just comes up to a minimum amount based on the max velocity that happens to be about 4 seconds from zero to max. Right now all I can do is switch it back and forth depending which spindle I'm using, but once I start running parts that do turning and milling in the same program, it's not gonna work other than letting my main spindle run at its minimum rpm of 7200, which it automatically does if the max speed is set less than that
    There's a way to do it. I found a post where a guy needed to do the same thing. Something about editing the xml or something like that but couldn't find much on the details. If I keep digging I might be able to figure it out, but thought I would check here and see if there's an easy answer
    15362
    Quote Originally Posted by QuinnSjoblom View Post
    What do you have the ON Pos Range set at in the Dmm Drive
    Mactec54
    Nov 2017
    591
    Default. I believe it was 127. I don't really see it as an issue with the drive settings though. 0 to 3k rpm in half a second with a heavy servo and spindle is a lot to ask. The problem is I can't set a reasonable acceleration in mach3 because of the max velocity I have to set to make the spindle swap work
    Ok, I think I see what you mean. If it gets set to a low number, it can send an alarm to mach3 with only a small position error. 127 only sends alarm if the drive faults which is how I have it set, so not my issue. I think it's simply just too high of acceleration. It's a lot of mass to go from zero to 3k in a half second
    15362
    Yes the mass and the inertia could be where the problem is
    In Mach3 spindle set the Velocity and acceleration to the lowest numbers, that work for you, velocity can be 0 and acceleration can be 1 so you can play with those numbers to get where you want to be
    Mactec54
    Nov 2017
    591
    Ok, found some details on the subject. Here's a quote:
    "The great team at Artsoft hooked me up, for those who are curious:
    If you open your XML File in a word editor(IE: Note Pad or Note Pad++) you can manually change the Acceleration to what you would like. Once the XML is open search(CTRL-F) for ACC0 for the X, ACC1 for the Y, and ACC2 for the Z. Save the file run mach3 and you should be good to go.
    by XML, he was referring to the XML for the Mach 3 profile I wanted alter.
    Happy Hunting!"
    I haven't tried it yet but will when I get home. I'm assuming the axis number for spindle is 6 as it is when doing axis swaps so i should find it by searching for ACC6 in the xml file.
    There also another solution that is simpler as you can enter it right in vb editor, but I'm not sure what exactly the code should look like. For setting x accel for example it's:
    SetParam "AccelerationX", then value
    For spindle accel, I'm assuming use "s"? Not sure though. I'll try this before digging through xml
    15362
    Happy Hunting!"
    Yes you should be able to swap the pulleys settings as well, then have a different acceleration and velocity profile
    Here is a video how to do it https://www.youtube.com/watch?time_c...&v=KkQso5yWj3A
    Mactec54
    Nov 2017
    591
    Great, that's good to know and probably the best solution since I can set the mill turn spindle velocity to it's actual max velocity instead of just putting in 24k yo match the main spindle.
    Here's another thing that's funny, a few days ago I ordered a braking resistor since I figured it would probably at least help the drive handle quick deceleration. Apparently it does and also helps with acceleration as well. I just wired it up and now I can ramp up and down from 0-3k rpm with a half second ramp no problem lol. Just cycled it up and down like 20 times without a single fault. without the resistor it would fault most of the time on ramp up and all the time on ramp down. Looks like now I can just leave it on crazy ramp speed. I guess why not. As a mill turn spindle, quick ramping will save cycle time since it switches back and forth from turning to indexing. I'm really surprised it handles it now. Half a second is pretty crazy. I guess it might be hard on the belt to leave it this way
    15362
    Breaking Resistors have a habit of working like that, this is what they are used for, anything that has / needs high deceleration rates needs a braking resistor more so because of the high inertia you have, not so much on the acceleration but may help if it is part of the acceleration circuit, the way the Braking Circuit is designed it is normally only affective on the deceleration side, but for a servo drive like this knowing the designer of these drives he most likely covered all possible situation's
    Your Mill spindle will benefit from a braking resistor also if your VFD Drive supports the use of one some of the cheaper VFD Drives don't have all the internal electronics parts needed
    Mactec54
    Nov 2017
    591
    I'm pretty sure my vfd allows it. Until now I kind of assumed breaking resistors were more expensive than what they are, so I never really considered using one. Now that I know i can get one for 20 bucks, I'll probably add one to the vfd as well so I can increase the deccel and save some more cycle time. I imagine it's also easier on the vfd
  1. Question on velocity and acceleration settings in mach3
    By uberlinuxgeek in forum Shopmaster/Shoptask
    Last Post: 09-25-2015, 03:10 PM
  2. Does Mach3 use video acceleration?
    By nekidfrog in forum Mach Software (ArtSoft software)
    Last Post: 04-16-2014, 04:54 PM
  3. Replies: 3
    Last Post: 01-11-2014, 05:32 PM
  4. Acceleration Rate Mach3/others
    By metriccar in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-28-2013, 03:55 PM
  5. how to reduce default max axis velocity?
    By bebob1 in forum LinuxCNC (formerly EMC2)
    Last Post: 05-30-2012, 08:58 AM
