603,796 active members*
3,283 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > How do I ID the leads on a 8-wire stepper?
Results 1 to 6 of 6
    Jun 2005
    38
    OK, so here's my problem: Bought these from China for a customer but it turns out the leads are not correctly matched to the coils according to the wiring diagram. I know my customer is not the problem because the other torque sizes work fine and he knows what he's doing when it comes to wiring motors.
    So I managed to find the correct pairing in parallel config by trial and error which I confirmed by being able to rotate the shaft by hand for each of the four pairs. But that leaves me unable to arrive at how to order the pairs to A A- B B- to connect to the drive.
    What baffles me most is that when I check the resistance of the pairs the multimeter shows the rated resistance of series config. In fact, all the of the eight leads give this same value. And no matter how I pair them--same thing.
    Any help/advise would be greatly appreciated.
    Aug 2019
    31
    Could you show me your motor's brand and its model?
    Dec 2012
    204
    Re: How do I ID the leads on a 8-wire stepper?
    let's call the pairs for this moment 1- 1+, 2- 2+, 3- 3+, and the last 4- 4+
    connect 1- and 2- together and 1+ 2+ together if you can rotate the motor free, that you found the A pairs and even the right - and + connection.
    If rotation is not free, connect 1- and 2+ together and 1+ and 2- together. Running free, you found the pair, but - and + of the 2 needs to be reversed.
    If it's still not rotating free, connect 1- and 3- together and 1+ and 3+ together and so on. following this you should find the connections
    Jun 2005
    38
    Quote Originally Posted by Toinvd View Post
    Thanks for this. The idea intrigues me. I have four pairs. But I have no way of knowing within a given pair which one is + and which one is -.
    Dec 2012
    204
    It doesn't matter if you call them + or - if all coils have the same Ohm resistance i'ts fine then you don't even have to take care for coil1 or coil2 l
    Take one pair and label this first pair as A1- and A1+ ( don't mind which one is + or - )
    Find the pair which you can connect in parallel to this such that the motor rotates free ( all other 4 wires disconnected ) and when found, label the one connected to A1- as A2- and the one connected to A1+ as A2+
    Now do the same for the other two pairs, label one pair as B1- and B1+
    put them in parallel such that the motor rotates free and label the one connected to B1- as B2- and the one connected to B1+ as B2+
    If you connect your motor to a driver and it runs in the wrong direction, just reverse one side. like B1- will be B1+ , B1+ will be B1- , and B2- will be B2+ , B2+ will be B2-
    Only reverse one side otherwise the motor will again run in the wrong direction.
    Jun 2005
    38
    I'll give it a whirl, thanks!
  1. Replies: 7
    Last Post: 02-18-2013, 01:23 AM
  2. Stepper Motor Leads....
    By slowtwitch in forum Mikinimech
    Last Post: 06-30-2011, 10:02 PM
  3. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  4. 5 phase stepper 6 or 10 leads
    By resuengineering in forum Stepper Motors / Drives
    Last Post: 07-07-2010, 01:56 AM
  5. connect wire leads to IC
    By Karl_T in forum CNC Machine Related Electronics
    Last Post: 06-11-2008, 06:15 PM
