588,174 active members*
4,465 visitors online*
IndustryArena Forum > MetalWorking Machines > Mikinimech > Stepper Motor Leads....
    Jul 2006
    367
    Some weeks ago, my "X" axis stepper stopped working. I haven't posted anything due to my ongoing spindle problems
    Anyway, the "X" axis kinda froze solid. I couldn't turn the ball screws by hand when the machine was off. I didn't know if it was the stepper motor or the lead screw, that was bad. Fortunately, I removed the 4 bolts that hold the motor in place and was able to turn the ball screw and I was able to get at the set screw on the coupling.
    It turns out that coolant has been entering the motor ( small amounts over time), thru the hole where the motor leads go into the stepper.
    Upon inspection, i noticed that the leads (at the 3 o clock position)went straight into the motor in a downward fashion, after they go thru the wire restraint at the edge of the table. By adding a small drip loop, would probably rectify this problem.
    Here is a picture of the damage..
    When i reinstalled the new motor (Keling KL34H280-45-4A, 640 oz-in), I positioned the lead opening at 6 o clock.
    After hooking everything up, my "X" is running again
    Hope this helps ...
    pete
    Feb 2009
    2143
    Thanks for the heads up!
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
  1. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  2. 5 phase stepper 6 or 10 leads
    By resuengineering in forum Stepper Motors / Drives
    Last Post: 07-07-2010, 01:56 AM
  3. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum News Announcements
    Last Post: 06-07-2010, 09:59 AM
  4. 8 leads Stepper Motor with Encoder
    By victor888 in forum Stepper Motors / Drives
    Last Post: 01-04-2008, 02:47 AM
