603,802 active members*
5,095 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Joes CNC Model 2006 > Fanuc 21 M - Memory card, DNC option not showing on controller
Results 1 to 6 of 6
    Exclamation Fanuc 21 M - Memory card, DNC option not showing on controller
    I have Excel make VMC with Fanuc 21 m controller.
    I have connected 2GB memory card (Fat and 64k formatted) using adapter behind the machine.
    On the screen I/O channel range is only 2 where as i need to put 4 for memory card. When I give input I/O channel - 4, Data out of range error comes.
    What should i do?
    screen image link - https://ibb.co/M5RHrBV
    Even there is no option to read memory card. when i go to Remote->Programm-->Dir
    Screen image Link below -
    https://ibb.co/YR38VwP
    https://ibb.co/2gGHhQG
    https://ibb.co/0MRS0Vt
    Re: Fanuc 21 M - Memory card, DNC option not showing on controller
    You need an i series control to use that card. I also suggest staying below 1 GIG when you do. The easy way to tell if you have an i series controller is to look at the servo drives and see if a fiber optic cable is attatched to each servo drive. (You will also have an FSSB page under the SYSTEM button). If you don't then that slot is only use by an SRAM card and the SRAM card can ONLY used on the PMC page and BOOT mode. You must use the RS232 to get programs in and out of the controller.
    Hi drdos, thanks for the reply.
    There is no FSSB page under the SYSTEM button.
    I have tried connecting through RS232 port. I am able to send the program successfully through my PC system but there's no option on the machine controller to check the program.
    I have checked in all modes. There's no option like "Device", "MEM", "DNC-CD" showing up in my controller. Please check video
    Controller Buttons link - https://ibb.co/rygW17W
    Video Link - https://youtu.be/uotdF0VWb5Q
    Where can i read the program?
    Looks like all you have is the program number. The rest of the program is missing that is why you don't see any program to edit. Make sure that you don't have a % after the program number or some kind of special charter.
    Feb 2009
    6028
    You won't have a DNC mode, it was called tape mode back then. won't have "Device", "MEM", "DNC-CD" either. That was on newer controls.
    Exclamation Re: Fanuc 21 M - Memory card, DNC option not showing on controller
    Quote Originally Posted by underthetire View Post
    There's no TAPE mode either. What should I do? Please help
  1. Replies: 1
    Last Post: 01-12-2016, 07:06 PM
  2. Replies: 10
    Last Post: 05-28-2015, 08:16 PM
  3. Fanuc 16i-M memory card
    By pawlosgr in forum Fanuc
    Last Post: 03-25-2015, 02:34 AM
  4. Fanuc Memory card
    By CNC1970 in forum Fanuc
    Last Post: 04-05-2014, 05:26 AM
  5. Fanuc 16i memory card
    By jamie pinols in forum Fanuc
    Last Post: 02-26-2007, 01:50 AM
