603,818 active members*
3,969 visitors online*
Results 1 to 6 of 6
    Aug 2012
    11
    Fanuc 16i-M memory card
    We got two different machines with the same controller Fanuc 16i-M, both are equipped with memory card slot. on one i can choose channel from 0-35 and other only 0-3, to use card is channel nr 4. when i put card in and set to nr 4 machine goes to message on black screen and emergency state. Can someone help with solving that problem?
    Thank You
    Apr 2009
    1401
    Re: Fanuc 16i-M memory card
    parameter 20 has the channel value; can you change it there?
    Which alarm message do you get?
    Aug 2012
    11
    i didnt try to change 20. its goes like windows to blue screen but there is black. never read it
    Feb 2009
    6028
    i've seen this on the early 16iMA controls. They can't use flash cards, would only read SRAM cards. I remember trying this on a showroom machine when that control first came out.
    Apr 2009
    1401
    from the maintenance manual (63005) :
    By setting the I/O channel (parameter No. 20) to 4, files on a memory card can be referenced, and different types of data such as part programs,
    parameters, and offset data on a memory card can be input and output in text file format.
    Can you change parameter 20?
    What is the software version on the problem control?
    Aug 2012
    11
    i dont know the software ill check it tomorrow in the morning
  1. Fanuc Memory card
    By CNC1970 in forum Fanuc
    Last Post: 04-05-2014, 05:26 AM
  2. Fanuc 3Ti memory card issues
    By starkey2600 in forum Fanuc
    Last Post: 11-04-2012, 04:09 AM
  3. memory card of FANUC 15MB
    By jeff.liu in forum Fanuc
    Last Post: 05-08-2011, 01:37 AM
  4. Where/How to buy Fanuc Memory Card
    By marcwdci in forum Fanuc
    Last Post: 07-19-2008, 02:57 PM
  5. Fanuc 16i memory card
    By jamie pinols in forum Fanuc
    Last Post: 02-26-2007, 01:50 AM
