603,975 active members*
3,320 visitors online*
Results 1 to 5 of 5
peteeng UCCNC & AXBB-E combo 06-02-2020, 12:05 PM
phomann Re: UCCNC & AXBB-E combo 06-02-2020, 12:18 PM
peteeng Re: UCCNC & AXBB-E combo 06-02-2020, 12:42 PM
phomann Re: UCCNC & AXBB-E combo 06-02-2020, 12:48 PM
ericks Re: UCCNC & AXBB-E combo 06-02-2020, 01:14 PM
    Jul 2018
    6841
    Hi All- I'm designing a new mill and want to use UCCNC and the AXBB-E. I use UCCNC so all good there. Is the AXBB-E all that's needed? I will have XYZ and a slave on X and a slave on Z so need 5 axes. UCCNC has 6 and AXBB-E has 6 I believe. Any suggestions or experience with this? or better options?
    Also I'm looking at the steppers with integrated drivers any experience with these out there?
    https://cncdrive.com/AXBB.html
    https://www.omc-stepperonline.com/is...-12-38vdc.html
    would like it to be a bit higher voltage and lower inductance though...
    cheers Peter
    Hi Peter,
    The ABXX-E is a good choice. It eliminates the need for a breakout board. It has spindle speed built in.
    This is a 4 axis controller I’ve started putting together for a customer.
    I also have some other images on instagram.
    https://www.instagram.com/homann_designs/
    Cheers
    Peter
    Homann Designs - http://www.homanndesigns.com/store
    Jul 2018
    6841
    Thanks Peter - Will it do 3 axis with two slaves? Peter
    It does six axes. I’ll have to check if it can have slaves on two of the axes(5 motors in total).
    I can check in the morning.
    Cheers
    Peter
    Sep 2019
    197
    It can have slaves on x, y and z
  1. New build using AXBB-e and huanyang vfd
    By Chmexdf5633 in forum Spindles / VFD
    Last Post: 04-14-2020, 01:42 AM
  2. Its Aliveeeee my AXBB-E is working
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 01-31-2020, 01:39 AM
  3. Axbb-e not Lnking to PC through UCCNC (no Blue Light)
    By BigFellaPhil in forum DIY CNC Router Table Machines
    Last Post: 01-01-2020, 12:18 PM
  4. my AXBB-E and UCSB are on the way, small annoyance is anyone using axbb with mach3?
    Last Post: 05-17-2019, 03:50 AM
  5. New AXBB controller
    By ger21 in forum UCCNC Control Software
    Last Post: 03-20-2019, 11:55 PM
