587,517 active members*
3,436 visitors online*
Results 1 to 5 of 5
    Angry Exceeding Machine Max/Min
    Hello, I am a total newbie to using the PathPilot Software, but I am attempting to use Fusion360 to manufacture some drawers for the local innovation center. When using PathPilot to simulate the manufacturing process on a Tormach 24r I keep getting the same errors, which display "Program exceeds machine Maximum/Minimum on _ axis. I have tried everything I know to do in Fusion360 in the Setups and Post Process I know to do but can only very slightly change the expected error on PathPilot. If anyone can help that'll be greatly appreciated! I will attach a photo of the error message from PathPilot below. Also, any suggestions to prevent this from happening again would be useful!
    Nov 2007
    2151
    Re: Exceeding Machine Max/Min
    It looks like you need to set your offsets x,y,z used in g54 to a place inside the actual machine limits. This needs to be done at the machine not in fusion.
    Hard to say more without an actual clip of what you have setup in fusion. And where your g54 offset is located in cam. And on the machine to see what problem is
    Nov 2007
    2151
    If you understand offsets and how to set them, this should explain the problem
    The example below will generate a similar error when the code is loaded into path pilot at the machine. The reason is the part/ program uses most if not the entire machine envelope or limits making a spoil board.
    This program will error out and not run until you set the g54 offset at a place the entire part or program fits within. in this case its near the back and left 0,0, limit of the machine.
    Attachment 472640
    if your part is smaller then the machine limits then it should be no problem to set the g54 x,y,z, offset to any place in that area and it will load and run
    like shown below.
    Attachment 472642
    this is just a small program with x,y,z located anywhere in the machine envelope and no where near the limits.
    note examples are shown using sprutcam with a very accurate machine limits definition and simulation shown. I dont know what fusion uses for such things but it should not matter if it all fits inside the working area of the 24r router machine.
    Can you please send those attachments a second time, they are giving me error messages now?
    Nov 2007
    2151
    like shown below.
  1. min / max operators on okuma ?
    By deadlykitten in forum Okuma
    Last Post: 01-21-2016, 09:24 AM
  2. THC Min and Max not Native
    By ryanthegreat1 in forum Mach Plasma / Laser
    Last Post: 01-14-2014, 01:20 AM
  3. evaluate MIN/MAX!!!
    By astra330 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 08-15-2011, 08:18 PM
  4. Max Min Positions Help
    By JWB_Machining in forum Haas Mills
    Last Post: 10-30-2008, 03:04 PM
  5. Getting my THC Min and Max to trip
    By JaiTalkin in forum Mach Plasma / Laser
    Last Post: 06-27-2008, 01:34 AM
