588,193 active members*
6,004 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 4th axis zero return question
Results 1 to 6 of 6
    Jul 2006
    11
    At the end of my programs my post calls for a G28 A0. This returns my rotary table to 0 but my screen reads 360. When I restart the program the rotary table goes all the way around and reads 0. Isn't 0 and 360 the same place? Is there a parameter to make it recognize this?
    Sep 2005
    767
    There is a parameter to set the display to zero when you zero-return. You could do the same thing with:
    G28 A0
    G92 A0
    What model Fanuc control?
    Jul 2006
    11
    Control is an OMD. How does a G92 affect this?
    Aug 2007
    21
    I always have programmed it: G91 G28 A0. This takes care of the position display on 11M 15M and up. I don't know about OM though.
    Sep 2007
    217
    We have 2 OM with 4th axis and we do it with the G91G28X0Y0A0.
    Feb 2006
    1792
    Quote Originally Posted by drgbt View Post
    Just a wild guess (I am not an expert):
    No, 0 deg and 360 deg are not the same, even though the angular position is same. Perhaps the reference angle defined on your machine is 360 deg, and not 0 degree. If so, redefine the reference position for A-axis, and make it 0 deg. This should be possible through a parameter setting where you enter the coordinates. Normally, up to 4 reference positions can be defined, and you can choose where to go (you have to use G30 P_ A_ instead of G28 A_ on OM control). If your machine does not have absolute position detector, then first G28 or manual reference position return will have to be used.
  1. ZRN (zero return mode) in fanuc 0m
    By PRIOR666 in forum Fanuc
    Last Post: 11-12-2011, 06:12 PM
  2. Fanuc 0-m zero return problem
    By jlong58 in forum Fanuc
    Last Post: 07-23-2007, 02:36 AM
  3. Return to Home Fanuc 0M-A
    By cnc4tr in forum Fanuc
    Last Post: 12-31-2006, 10:07 AM
  4. Fanuc 5T Zero Return Problem
    By Stu-Jitsu in forum Fanuc
    Last Post: 10-27-2006, 04:05 PM
  5. Fanuc 18M Z return
    By pinguS in forum Fanuc
    Last Post: 07-27-2006, 03:43 AM
