603,855 active members*
4,044 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > ZRN (zero return mode) in fanuc 0m
Results 1 to 7 of 7
    May 2006
    46
    Hello to all people of this forum
    I have one cnc miller with control fanuc 0m and have the next issue, i cannot index my machine (home position) the micros work fine but the axis travel stop before touch them and the NC send me over travel alarm (it seems as software limits or something) somebody knows like i can configure this?
    thank you.
    May 2007
    1003
    I sometimes have the same problem on our MS200 Daewoo lathes after some one crashes them. If it is the same problem with your mill, then you need to know the parameters where the machine envelop (I guess this would be the correct description) for each axis is located. Write down the current values. Hopefully they are correct. They should be in an envelop that came with the machine. The values set by the manufacturer may or may not match the current values depending on what has happened in the interim.
    Set the values to something like 99999999. You should be able to return to machine home now. Change the numbers back to the original. Power down and back up (not necessary on our lathes, but may be on your mill). It should home, provided this was the problem to start with.
    Otherwise I can't help you. I am not maintenance. Just a lowly programmer.
    Dec 2003
    24260
    Try Power off the control and before you power it on again the push and
    hold at the same time the letter "P" and the "cancel"button then power up
    the control, hold down the two buttons until the control powers up
    completly. Perform home routine.
    This overides the soft OT limits.
    Al.
    Albert E.
    Nov 2003
    98
    Here is some additional info on the Om control. Either of the above replies should cure your OT problem before reaching home position.
    Diagnostics
    #452 Turret adjust switch. Make all 1's then cycle estop to clear tool clamp alarm and allow you to tool change to another tool.
    #016 X axis home limit (Bit 5)
    #017 Y axis home limit (Bit 5)
    #018 Z axis home limit (Bit 5)
    #720 X axis alarm bits
    #721 Y axis alarm bits
    #722 Z axis alarm bits
    Parameters
    #700 X axis soft limit +
    #701 Y axis soft limit +
    #702 Z axis soft limit +
    #703 4th axis soft limit +
    #704 X axis soft limit -
    #705 Y axis soft limit -
    #706 Z axis soft limit -
    #707 4th axis soft limit -
    I believe these are right. May have the +/- backwards.
    #535 X axis backlash adjustment
    #536 Y axis backlash adjustment
    #537 Z axis backlash adjustment
    #128 Tool # (actual tool in spindle)
    #129 Tool # (number of tools magazine will hold)
    #9122 Tool Change spindle orientation adjustment. Minus=CCW Plus=CW
    #22 Home Position Memory X=bit 0, Y=bit 1, Z=bit 2
    Bob
    May 2006
    46
    thank you very much for the information
    apparently this is the information that i need, today i will check your suggestions and post the result.
    thank you, this site is awesome.
    May 2006
    46
    the problem i'ts resolved
    thank you very much
    with the parameters i could reach the home switch.
    Jul 2010
    change the drivers battery first
  1. Fanuc Zero Reference Return Problems?
    By grege101 in forum Fanuc
    Last Post: 09-19-2023, 12:52 PM
  2. Return to Home Fanuc 0M-A
    By cnc4tr in forum Fanuc
    Last Post: 12-31-2006, 10:07 AM
  3. Fanuc 5T Zero Return Problem
    By Stu-Jitsu in forum Fanuc
    Last Post: 10-27-2006, 04:05 PM
  4. Fanuc 18M Z return
    By pinguS in forum Fanuc
    Last Post: 07-27-2006, 03:43 AM
  5. Fanuc tape mode
    By mroy0404 in forum Fanuc
    Last Post: 03-17-2005, 10:15 PM
