587,614 active members*
3,780 visitors online*
Page 1 of 12 12311
Results 1 to 20 of 237
    Jan 2006
    509
    RemainCNC NZ Excitech 1530 router.
    Hi guys,
    I have recently (read today) received a 1530 Excitech router from China. It will be another week and a half until we get the power connected. There are a few minor niggles (to be expected) but overall very happy with the amount of machine for the price.
    Here are some pics.
    Shannon.
    Attached Thumbnails Attached Thumbnails DSC02876.jpg   DSC02881.jpg   DSC02885.jpg   DSC02893.jpg
    Dec 2006
    878
    Bloody Ripper Mate!
    G`day Shannon, Welcome to the wonderful world of Excitech cnc Routing!
    Great pics, looks like you did not need the chains to get the crate out of the container. From the pics it appears to have come out quite easily.
    Good looking compressor too!
    So what are your initial thoughts of the machine?
    Rocket.
    Jan 2006
    509
    Quote Originally Posted by rocket67 View Post
    Rocket.
    I think it is a solid machine and very good value for the money, We did use the chain for a little to drag the crate further away from the container but with a decent forklift (longer forks) even that would not have been needed.
    Getting the machine onto the car transporter was a bit of a drama, we ended up taking some of the side panels off the machine and putting the forks through the side to lift it onto the trailer. Getting it off was easy
    I will re lay the T-slot aluminum that is on the bed, its not the most level bed in the world. and quite a few other mods planned too.
    Shannon.
    Jan 2008
    48
    Shannon,
    Looks like they have re-designed the control compartment that normally sits along-side the router. Perhaps they have addressed the problems Rocket was having with connecting the hand-held controller.
    Did you get the vacuum/T-slot table in preparation for vacuum later? If so, how many vacuum zones does it have and how is the table divided?
    Thanks,
    Spencer.
    Nov 2007
    2466
    shannon
    are those alignment pins on the table and how about a down photo of the table!! looking good jim
    Jan 2006
    509
    Quote Originally Posted by BC-CNC View Post
    Shannon,
    Thanks,
    Spencer.
    I was hoping to get the box that sits along the side of the machine like rockets one but its not too much of an issue as I am planning to install the electrics under the bed anyway. Other purchasers may be best to specify what type of control box they want. as I will be doing if/when we get a future purchase
    I didn't get a vacuum bed of any sort just a T-slot table, but I am going to make my own. I hope to divide the bed into a separate 4' x 8' vacuum zone for doing smaller sheets as well as the ability to hold down large sheets.
    Shannon.
    Jan 2006
    509
    Here is a few more random pics, I will try to get a good shot looking down on the bed too.
    Shannon.
    Attached Thumbnails Attached Thumbnails DSC02900.jpg   DSC02901.jpg   DSC02905.jpg   DSC02904.jpg
    Nov 2007
    2466
    shannon
    whats in the big wrap behind router on trailer cotton or hay ?? jim
    Jan 2006
    509
    Thats hay, for the dairy cows.
    Shannon.
    Jan 2007
    68
    Great Pictures
    Hello Big S,
    I just ordered my 1530 so I'm really enjoying your pictures and unloading experience. In a previous post you said you did not order the dust extraction unit but got the dust shoe which you pictured above. Is the shoe standard or did you order it as an option.
    Thanks, Mitch
    Jan 2006
    509
    Mitch,
    I didn't order the dust shoe but it came with the machine, It will be quite handy but I may change the design of it so we can get at the tools easier to change them.
    A couple more pics .
    Shannon.
    Jan 2007
    68
    Thanks Big S,
    That's what I thought, but I wanted to make sure. I look forward to your continued pictures and experiences with the Router.
    Mitch
    Jan 2006
    509
    I have installed the DSP driver on my computer and also the Ucancam v8 software.
    I had a few issue with getting the DSP to be recognized. I ended up installing the software off the CD first, then rebooting the computer before connecting the DSP to the USB cable. I am not entirely sure why the DSP needs to have drivers installed on the computer as it doesn't seem to be able to connect or anything.
    The Ucancam software seems to be ok, its sort of a cross between autocad and corel draw but fairly basic 2D CAD and 2.5D CAM. It should be usable and I intend to try it out as soon as the machine is connected up to the power.
    The Ucancam software has some neat features like wave board and cam preview.
    Shannon.
    Jan 2006
    509
    I removed the HSD spindle off the router tonight and cleaned out the rust inside the ISO30 taper. It was probably the biggest disappointment on the whole machine as it is a very critical surface. The rust looks a lot worse in the pics than it really was, there is a VERY slight pitting in places now but the tool holders sit in nice and neat. I don't think it will be an issue at all.
    I cleaned it out by putting a clean piece of rag in the hole. Then starting with a blunt scalpel knife to get the worst of the rust then used some steel wool, then finally the wire wheel on the dremmel. I deliberately avoided sandpaper as it would have removed the good metal from the precision ground surface. There is plenty of good surface left to make a good contact tool holders so all is good.
    I have advised Taney and he is going to sort out the issue in future by putting a plug or something over the hole so the moisture cannot get in when the routers are shipped.
    In the photos you can see the four bearings the grip on the under surface of the pull stud on the tool holder at the inside of the taper.
    The last pic is with the rag stopping junk from getting inside the drawbar.
    Shannon.
    Attached Thumbnails Attached Thumbnails DSC02939.jpg   DSC02942.jpg   DSC02940.jpg   DSC02948.jpg
    35538
    Quote Originally Posted by Big S View Post
    I removed the HSD spindle .............
    When we sent our spindles to HSD-USA to be rebuilt, they returned them with a soft, thick plastic cap that slips onto the entire bottom of the spindle. I would have to think that HSD makes these, and although they are probably for shipping spindles separately, they would probably prevent what happened to yours.
    Jan 2006
    509
    I was aware that HSD made the caps as I have had a pdf copy of the manual for a few months now. I was a little surprised and quite disappointed that one wasn't fitted when the router was shipped. I have MSN'ed Taney about it and sent a photo of the damage before I cleaned it up. Hopefully Excitech get the next ones protected during shipping.
    I am considering making something to cover the hole for when the machine is not in use as the HSD manual recommends that tool holders be removed when the machine is not in use overnight. There is also a blank tool that covers the taper that can be put in a tool changer to be selected at the end of the day. I have not seen pictures of one however.
    Shannon.
    Jan 2006
    509
    Make sure linear bearings get their grease!!
    I had a look at the damaged Zaxis bearing block seal today, I ended up taking three of the blocks off the Zaxis and cleaning them. One had the grease nipple facing the wrong way too, so that is sorted out now. The swarf on some of the blocks is how they came off the machine, there was no swarf inside of the blocks however. I don't think it will be too much of an issue not cleaning it off as dust and all sorts is going to get all over these areas when machining. The seals on the linear rails should stop anything getting into the bearings.
    I did notice that there has been no grease of any sort put into the blocks, something people need to be aware of when getting their machine. I was quite surprised that Rockets machine was binding up when not greased for a while, the multicam at work goes ages between lubrications (not good for it really). When it gets done the grease comes out past the seals on the blocks, so there must be a fair bit in there.
    Also pics of the ball screw and nut on the Z, and the insides of the back half of the control box.
    More to come.
    Shannon.
    Attached Thumbnails Attached Thumbnails DSC02958.jpg   DSC02959.jpg   DSC02962.jpg   DSC02963.jpg
    Dec 2006
    878
    Great Stuff!
    Hi Shannon - Fantastic photos and commentary!
    I would not have the balls to pull apart a new machine. You obviously know your stuff.
    It was good to have a look at the inside of those blocks too. When our machine was binding up - as you describe it - i put a few shots of grease into the blocks. It was possible that as the rails had not been wiped or oiled for a while, that a sliver of mdf had become wedged under the block and was pushed out by the grease.
    Even though the rails down the side of the machine are protected by the spill tray on the edge of the table, it is incredible to see how quickly the MDF dust builds up on the rails. So it is very important to wipe the rails with a cloth and oil them daily.
    Rocket.
    Jan 2006
    509
    That MDF dust is a killer, its bad to breath in and seems to get EVERYWHERE.
    Here's a few more pics, we can't have too many can we Oh theres one of our cat.. how did that get in there
    I am not sure what the small pressure bottle is for and haven't got around to asking Taney about it, any guesses?
    Shannon.
    Attached Thumbnails Attached Thumbnails DSC02911.jpg   DSC02912.jpg   DSC02918.jpg   DSC02913.jpg
    Jan 2006
    509
    Slow progress
    Did a little more today, cleaned out the side covers on the gantry, took the covers off the Y-axis rails and cleaned them down. I also started working out a movable material rack.
    Also shifted the machine closer to where it is going to sit in the workshop, although it still needs to be leveled.
    Shannon.
    Attached Thumbnails Attached Thumbnails DSC02987.jpg   DSC02992.jpg   DSC02994.jpg   DSC02995.jpg
Page 1 of 12 12311
  1. Excitech Cnc Router Purchase
    By rocket67 in forum Excitech routers
    Last Post: 03-28-2018, 03:16 PM
  2. 1530 ATC CNC Router CC-MS1530AD
    By cherry.CC in forum News Announcements
    Last Post: 04-08-2013, 09:15 AM
  3. Excitech 1212 router down, need help.
    By JacquesLeDick in forum Excitech routers
    Last Post: 08-25-2012, 07:23 AM
  4. Excitech new changes for CNC router
    By dianafeng in forum Excitech routers
    Last Post: 12-02-2008, 02:14 AM
  5. The sh-cnc Excitech 1530 B
    Last Post: 08-13-2008, 06:53 PM
