ok
so I have an old thermwood c50 (1987)that I want to retrofit with kflop/kanalog
I just got the kflop/kanalog boards in and really don't know where to start
I already have a license of Mach3 so will probably use it
x axis has 2 dc servos y has one and I have 2 z's + 2 air drills
all servos are the same baldor mte-4535-special 40 lb. in. max speed 4500 rpm max voltage 180 vdc 16.4 amps constant 70.2 amps peak
tach 7.0 encoder 625 L
I will be using my existing amps and power supply
encoders have +5v, common, shield, phase-A, and phase-B
tach has red and black wire
arm. has red and black wire
not sure where to start and don't want to burn anything up
anyone have an example of what connects to where? thanks
